Well I went for a drive everything was goin good and all of a sudden the clutch went to the floor and loss pressure so I put some fluid in and it is still doing it I can drive it the clutch dont slip and I can change gears but theres no pressure in the pedal you can push it in about a 1/4 of the way with no pressure and sometimes it will travel right to the floor ,,, What can be doing this im very worried ? we tried to bleed it like 5 imes and I guess there no air coming out? what can I do what could it be ?
i had the same problem and turned out to be just air in the line. try bleeding the clutch line
We bled the lines and there is no air , When I push the clutch in fast it has pressure but when I push it slow it goes all the way to the floor and stays there until I pull it up by hand. It has to be either the slave cylinder or the other cylinder on the firewall im hoping the fireweall one so I dont have to pull the tranny out for the slave cylinder.help me out anyway to confirm which one it is ?
