Today i was driving in town. And i when i Hit a Pot Hole, All the gauges in my car Died and the lights went out. Thing just died on me, lol. Ive got Underglow wires, and headlight strobes going to my Battery post, in addition to the power for my amp. But, and this is where the problem may lie...My Cd PLayer, which is Hard wired. Can be turned on Manually by me, and only shut off by me, it doesnt turn off when i turn the car off (key out). neways, it starts up On itZ Own Whenever my Gauges Go. After that pot hole, my Gauges go and my cd player turns on by itself everytime i shift ( slight jolt) lol. Maybe the Purple wire in behind my stereo is touching another one and throwing codes or something. I just Changed my Spark Plugs 2 days ago, doubt itZ got anything to do with anything. I just gotta figure out if itZ wires in behind my stereo, or wires touching each other on my battery. Maybe even the wire going to my fusebox??? Im lost here boys.
yea you might of jolted a wire loose of something...
http://www.cardomain.com/ride/2090440
Did you check the wire that goes to your battery terminal? If that's not it, it's defenitley a loose wire somewhere.
ThX NjHK, Ill check the battery Posts and see if everything is secure There. it happened today again like 6 times, lol.
Look next to the battery and check the ground on the bolt into the tray. That's a common one to go bad.
Brandon Badger wrote:ThX NjHK, Ill check the battery Posts and see if everything is secure There. it happened today again like 6 times, lol.
No problem and good luck.
Ok, i found it, lol. I opened up the hood, I seen that the Bolt came off the the piece that holds the battery in place so it doesnt rock around everywhere. So i noticed it was loose, gave the battery a little Jiggle, And the Positive Terminal on my battery touched the elbow of my Intake. Voila! Instant Sparks! lol. Whenever the battery touched the intake thats when everything must have shorted out. The intake even had some like wearing away from the Welding job that was There. You could tell it happened quite a few times. Im Just Lucky nothing actually set fire underneath my hood. ThX again you guyZ for your help and Direction as usual.
