fuel filter? - Maintenance and Repair Forum
fuel filter?
Tuesday, January 24, 2006 4:31 PM
Hey, I took my car into the dealership today to get a new fuel filter. The problem is they couldnt get it off, the quick realse is rusted up, and wont come off. They said they can cut the filter at end, (the long nipple), and dig it out of the metal line. They said there is a chance of the metal line breaking, if that happened, it would cost me in the mid $700 dollar range, because thats the line that goes to the fuel pump, and its all one unit they told me, so i ended up not getting it done, what do you think i shoud do, its a 98 z24.
Re: fuel filter?
Tuesday, January 24, 2006 5:02 PM
Cut it out of there and put in a generic in line fuel filter, those quick releases suck ass.
Re: fuel filter?
Tuesday, January 24, 2006 5:21 PM
hmmmmm, I had no problem with my quick releases
and for the feul pump side, all it is is a flare nut fitting. if it breaks(wich if you do it right it shouldn't even if its rusted) all you gotta do is get another piece of pipe, some fittings, and make you a flare end on the feul line.
there is no way on gods green earth that should cost you 700beans
Re: fuel filter?
Wednesday, January 25, 2006 12:53 PM
Dealers try to pull one over on you when ever they can; i wont take my car to the dealer.
Good luck; i was thinking of getting my fuel filter replaced; now i am scared,lol.
98 j-body sedan
Re: fuel filter?
Wednesday, January 25, 2006 1:04 PM
Tell them PB penetrator is you friend. Their excuse is BS.
Re: fuel filter?
Wednesday, January 25, 2006 1:27 PM
just do it yourself. its not hard.
GO PATS!!!
Re: fuel filter?
Wednesday, January 25, 2006 5:54 PM
tri-flow (teflon) that bitch.
Re: fuel filter?
Thursday, January 26, 2006 3:15 PM
will try.
Re: fuel filter?
Thursday, January 26, 2006 6:27 PM
that's a new one. trying to get you to buy a pump if the line breaks. aw man i have to remember that one. most parts stores are fully aware of this problem and have a variety of fuel line and fittings. i had to get a repair kit for mine as well, basically a flexible fuel line with a barbed adapter that joins the old line and new line (after heating the lines in hot water) and then has a quick connect fitting for the oem filter.
if it was the other end then get a tubing cutter and a flare kit and toss in a new fitting. either way it would be no more than a $20 fix.
