Is Vauxhall is same thing as Chevy? - General Forum
Thursday, February 08, 2007 11:12 PM
Hi Guys
I just wanted to know if Vauxhall is the same thing as chevy? because when I was searching on google I came across a website for cams for cavalier they listed as Vauxhall Cavalier? and I wanted to know if its the same thing or not.
<a href = 'http://ivpnewmedia.com/10thst/tifts/'>
<img src = 'http://ivpnewmedia.com/10thst/tifts/dpBanner.gif'></a>
Re: Is Vauxhall is same thing as Chevy?
Thursday, February 08, 2007 11:18 PM
nope.
edit: to elaborate further... http://www.j-body.org/forums/read.php?f=47&i=35234&t=35234
Edited 1 time(s). Last edited Thursday, February 08, 2007 11:20 PM
Thursday, February 08, 2007 11:24 PM
so you saying noting from vauxhall will fit into sunbird or cavalier motors correct?
Thursday, February 08, 2007 11:28 PM
exactly.
Friday, February 09, 2007 11:02 AM
Vauxhall is the same as Chevy in that they're both GM brands... but the Vauxhall Cavalier was not a j-body and is in no way related to the Chevy Cavalier. You shouldn't expect the parts to swap any more than you might expect the parts from an Astra to swap into a Cobalt. There could be some that are the same... but I wouldn't expect to find them.
Friday, February 09, 2007 11:15 AM
well they both use the eco dont they?
Friday, February 09, 2007 11:42 AM
Well technically, the 82-89 Vauxhall Cavalier was the same chassis as the 1st gen J's here in North America and around the world.... but the later ones were very different.
The "Ecotec" isn't just one motor... it's a whole family of GM engines now. The only Ecotec used here in J-bodies was the L61 2.2L DOHC version... but there's a lot of others... make sure it's the right motor before you go ordering parts from overseas
Friday, February 09, 2007 3:53 PM
Right... to add examples to Lenko's post... the Eco that's used in the Solstice is a 2.4L VVT -- meaning, most parts wont work.
There's a 1.8L Eco as well that's used overseas
So while an L61 is an Eco, not all Eco's are L61's
Saturday, February 10, 2007 8:46 AM
John Lenko wrote:The "Ecotec" isn't just one motor... it's a whole family of GM engines now. The only Ecotec used here in J-bodies was the L61 2.2L DOHC version... but there's a lot of others... make sure it's the right motor before you go ordering parts from overseas
What about the 2.0 Eco or the 2.4Eco?
And I think the Aveo uses something called EcoTec 2 or E-Tec 2 or something along those lines.
Saturday, February 10, 2007 9:39 AM
well M I N I O N is sayin that you can use the 88-89 2.0 dohc with XE parts.
Saturday, February 10, 2007 11:47 AM
here is what I got from M I N I O N in a PM
I'm confident you are asking about a 2.0 SOHC motor. Yes, the C20xe and C20let turbo cylinder heads will bolt up to an American 2.0 SOHC turbo or non turbo motor. The stronger rods and pistons can be bolted into the block. The crank can be swapped over. The thing is, the xe and let Euro motors use the same engine block from the same GM factory in Brazil as the American counterparts.
To swap the heads you need the full timing assembly, intake manifold and exhaust manifold. If you get the parts off of the turbo motor, this means a factory cast turbo manifold.
The biggest issue you will run into is the ignition system unless you are putting the parts onto a 2.0 mpfi.
If you decide to do a DOHC conversion, be sure to upgrade your internals. The DOHC heads will need DOHC pistons unless you have a 2.0 turbo motor where the pistons are dished. Also be sure to buy a Coscast version of the head, not a GM head. To diffentiate, the GM head has freeze plugs on the end of the head and Coscast does not. Coscast heads also have their logo stamped on the bottom between the three and four exhaust ports.
Saturday, February 10, 2007 2:11 PM
Sunday, February 11, 2007 9:27 AM
And nobody talks on the "Ecotec V6?"
Damn marketing.
>>>For Sale? Clicky!<<<
Sunday, February 11, 2007 9:38 AM
the ecotec name has been used sine the mid 90s in europe. the first motor to bare the ecotec name was actualy a 2.0l dohc, from the same engine family as the 1.8/2.0l sohc motor in the sunbirds. our current l61/lsj has evolved from that 2.0l ecotec, but its roots do come from the old 1.8/2.0l.
Sunday, February 11, 2007 2:24 PM
sharkey wrote:the ecotec name has been used sine the mid 90s in europe. the first motor to bare the ecotec name was actualy a 2.0l dohc, from the same engine family as the 1.8/2.0l sohc motor in the sunbirds. our current l61/lsj has evolved from that 2.0l ecotec, but its roots do come from the old 1.8/2.0l.
Try again, more like a clean sheet design and it has more common traits from the Saturn's 1.9L and Quad-4 family. The only thing that the Opel design Ecotec has in common to the American design Ecotec is the fact it is a 4cyl and its name.
Edited 1 time(s). Last edited Sunday, February 11, 2007 2:27 PM
Sunday, February 11, 2007 7:24 PM
here guys here what Minion told me about this
M I N I O N - Sinbird wrote:Who told you that?
Part of the reasoning may be that you asked for parts for a 2.0 DOHC? The other part may be that they have no idea what a pontiac sunbird is. Try asking if a c20let head can be swapped over to a c20get (2.0 sohc turbo motor code in Europe, doesn't go by LT3 there.)
If they still say it doesn't fit, to hell with them. The swap has been done by myself and one other J owner in the states to my knowledge, possibly more.
Monday, February 12, 2007 12:17 AM
Correct. In some circles, the 1.9 DOHC Saturn motor is referred to as the "Precotec" because of it's role in the development of the current American 2.2L rendition of the Ecotec motors. It was no coincedence that the first appearance of the Ecotec motor in the US was in a Saturn ION...the replacement for the Saturn S-series that held the 1.9L motors for so long.
The design took all the good things from the design of the GM Quad motors as well as the Saturn DOHC motors (off hand, originally intended in the early 90's to be cheap-to-build economy variants of the Quads) and combined them into one motor. The only real addition was the severe strengthening of the internals, as GM suddenly realized the real influence of the power aftermarket and decided to "future proof" the motors a bit.
09:f9:11:02:9d:74:e3:5b:d8:41:56:c5:63
Monday, February 12, 2007 1:16 AM
^^^^^ Actually it was first used in the saturn L100 and saturn L200 before the Ion.
I'm still unsure of the question that you are trying to ask me. Are you asking about parts for your ecotec or parts for a 1st or 2nd gen J-body? some of the earlier vauxhall cavaliers were built on the J platform so they share suspension components and things like fenders can bolt up, but unlike the american J's, they will not line up with your doors when you swap parts between GM subsidaries.
My sunbird's engine block:
Vauxhall Frontera engine block:
Ebay auction link for that block
By golly I think they look about the same.
Cardomain|Myspace
Monday, February 12, 2007 8:13 AM
M I N I O N - Sinbird wrote:^^^^^ Actually it was first used in the saturn L100 and saturn L200 before the Ion.
Ya know, I don't know why I typed ION. As I was typing that, I was picturing the car in my head, and I knew I was talking about the L-series. The L-series showed up with the Ecotec in 2000, then the ION followed in 2002.
That's what I get for posting at 3am.
