Scientists with the National Institute of Standards and Technology say their three-year investigation of the collapse determined the demise of WTC 7 was actually the first time in the world a fire caused the total failure of a modern skyscraper.
mclonedogmcwad wrote:Quote:
Why do i have a hard time believing that statement?
And I don't even follow the conspiracies
Corp. Punishment wrote:![]()
Fire spreads in South America’s tallest high-rise building in Caracas, Venezuela, because its sprinkler system had not been properly tested or maintained
The fire eventually burned itself out at 3 a.m. on Monday morning, after spreading and consuming the contents of some 17 floors, more than 24 hours after it began.
Pretty friggin increadable that this building can burn for 24 hours and not fall down. But WTC 1, WTC 2, and WTC 7, can burn fro 45mins, 1.5hrs. and 8hrs and all collapse from fire. Dosent take a genious to figure that one out.
t2 wrote:you know those buildings are designed to be able to take a plane crash and/or a much more powerful impact. And even the official story doesn't claim that the impact did anything(except dislodge heat shielding). In theory you should be able to fly planes into them all day long and get nothing. Hurricanes exert ALOT worse on skyscrapers - believe it or not.Corp. Punishment wrote:![]()
doesn't take a genius to figure out that planes flew into the wtc buildings causing damage too....?
i did a science experiment back in like 5th grade, we built a tower out of toothpicks, (about 5-6 ft high) then put weights on top.
then what do you know happened when the weight became too much? oh noes, it collapsed straight down
who woulda thought? (blah blah blah, its not the same as WTC, blah blah blah, ok, even if you put one 10lb weight on top, and took out middle toothpicks, its gonna fall straight down like a pancake, just as it did with our 3 towers back in 5th grade)
some people need to get a better education, sorry if i offend you, but keep believing there were bombs
t2 wrote:Corp. Punishment wrote:![]()
Mr.Goodwrench-G.T. wrote:Sounds like we found the latest conspiracy - the WTC towers where made out of toothpicks!! No wonder they collapsed so easily. It all makes sense now...t2 wrote:Corp. Punishment wrote:![]()
Thats it, the 5th grade science projects explained it all. We can now end the discussion and thread, because of such a enlightening conclusion.
