Window Stickers - Exterior Forum
Window Stickers
Wednesday, February 02, 2011 8:57 AM
hey anyone know of something good to take off window stickers. the 2001 z24 i bought came with chevrolet on the front windshield and cavalier on the back and using a blade isnt woking, leaving a sticky mess behind.
Re: Window Stickers
Wednesday, February 02, 2011 9:58 AM
first!
razor blade it then you goo gone or another adhesive or bug & tar remover on the leftover residue.
Re: Window Stickers
Wednesday, February 02, 2011 10:05 AM
Shaggy is correct. get the lettering off with a blade, then come back with some Goo Gone to remove the sticker residue.
Re: Window Stickers
Wednesday, February 02, 2011 11:25 AM
Thanks guys. first cav i bought and dont really know too much about them so thought i would join this site.
Re: Window Stickers
Wednesday, February 02, 2011 12:24 PM
professional opinion... burn(propane torch) it and then scrap all of it off w/ a razor... clean w/ alcohol...
I used to work at a print shop and that was the quickest ans easiest way to go about it...
Re: Window Stickers
Wednesday, February 02, 2011 8:55 PM
brian warren wrote:professional opinion... burn(propane torch) it and then scrap all of it off w/ a razor... clean w/ alcohol...
2010 Lonestar Bash 2nd place J-Body Street Class
Re: Window Stickers
Wednesday, February 02, 2011 10:00 PM
and that goes for glass only... when you move onto painted surfaces you have to be a lot better
w/ the heat... and use a plastic sticker applicator to scrap off the remains of the sticker, and use
alcohol and immediately wash the alcohol off w/ soap and water...
Re: Window Stickers
Thursday, February 03, 2011 8:14 AM
brian warren wrote:and that goes for glass only... when you move onto painted surfaces you have to be a lot better
For the body if your going to shave the emblems, wd40 worked best for me, worked wonders.
Re: Window Stickers
Thursday, February 03, 2011 12:10 PM
I'm just speaking trade secrets... this is the process a professional graphics shop goes by...
Re: Window Stickers
Tuesday, February 08, 2011 12:16 PM
Being I work for a print shop and do quite a bit of vehicle graphics, that just makes me cringe. Ive seen people do it with good results, Ive done it with good results. Ive also see numerous times where the rubber moulding gets too hot and distorts.
I personally prefer a good heat gun, a lot safer for the paint and trim.
3m also makes a wonderful citrus, non chemical adhesive remover. Best stuff Ive used.
Re: Window Stickers
Friday, February 18, 2011 10:06 AM
I remove vehicle graphics with goo gone, a razor blade and a heat gun. Have used that for over half a decade and works great. Goo gone can be found at Dollar Tree for the small amount you will need. If you don't have a heat gun you can use a hair dryer but it will take alittle longer.
Re: Window Stickers
Friday, February 18, 2011 9:55 PM
On glass, you can use a razor and a little gasoline. A heat gun is a good idea for body pieces, but definitely watch out for dealer stickers on plastic bezels, a little heat warps the bezel surface.
-95 CAVfire SE Sedan 2.2L *Retired*
-99 Sunfire GT 2.4L
-85 Dodge Shelby Turbo TII Roller Cam Build *in progress*
Re: Window Stickers
Saturday, February 19, 2011 11:14 PM
Yea, I guess it's just up to the shop... but, when u have to go outside, or do some on location jobs... you can't always ask for a plug-in... basically, just get good at using a propane torch...
Re: Window Stickers
Sunday, February 20, 2011 9:18 AM
i use carb cleaner to take off the sticky residue, but avoid plastic
Re: Window Stickers
Wednesday, March 09, 2011 7:57 PM
Get a heat gun like others have mentioned, i work for a body shop so i would know, just get the surface almost to hot to touch and start peeling, shouldnt evn need a razr, just my 2 cents
