i have an 04 cav, trying to figure out which fog lights to get? also the holes have lines in them so i was thinking of just cutting those out. sound good?
Are you ready to do all the wiring from the fog lights to your dash? You will have to hook it up to a button near your steering wheel.
Colby Kulyn wrote:i have an 04 cav, trying to figure out which fog lights to get? also the holes have lines in them so i was thinking of just cutting those out. sound good?
i have an 04 and i was thinking of doing the same thing. just dont know what to get yet.
Sig thanks to bxmobkrazey on gmscf.com
you can just relay them from you parking light if you dont mind them being one whenever the parks are.
damm dude dont spent $140 on fog light i got my blazer projector fog lights from autozone for $40 i think they work and look great and it only took like 2hr to hook them up
Just go to a yard and get some lights off another cavi... might get lucky... spending that much on fog lights is crazy
bump, I have been wondering this myself, what size are the stock ones? 3inch 4 inch...
Don't wire the relay so it's switched by the running-lights... At-least not without a switch in-line. That way you can fully control them whenever your side-markers are on. In fact, this method will even let you use them when your high-beams are on! That's the factory circuit would never allow you to do... But soooo worth-it when it's done while driving late@night on an empty country-road.
Go beyond the "bolt-on".
