So I mocked my kit up and I thought it fit fine. I am on my one side skirt at the moment and I've got it attached securely to the body, but there are tons of gaps everywhere. Especially where the door jams are and underneath the door itself theres a gap. How do I use body filler and sand some pieces off effectively. It doesn't look bad from far away, but when you get up close it is pretty bad. Thanks!
Justin
"What we do in life, echoes in eternity"
pics would help.
and i certainly wouldnt use filler to fill gaps if they're anything like im picturing.
some doblue sided 3m tape may take care of it
I have used 3m double sided tape and the stuff doesn't stick worth crap. It might be good for mocking your kit up to your body, but it certainly doesn't stay....Here are some pics:
<a href="http://tinypic.com" target="_blank"><img src="http://i46.tinypic.com/29lfm1j.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
<a href="http://tinypic.com" target="_blank"><img src="http://i49.tinypic.com/2it0px0.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
<a href="http://tinypic.com" target="_blank"><img src="http://i50.tinypic.com/t9e735.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
<a href="http://tinypic.com" target="_blank"><img src="http://i50.tinypic.com/23jsqe1.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
<a href="http://tinypic.com" target="_blank"><img src="http://i45.tinypic.com/2h6h9v9.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
<a href="http://tinypic.com" target="_blank"><img src="http://i46.tinypic.com/rm09cg.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
<a href="http://tinypic.com" target="_blank"><img src="http://i48.tinypic.com/2u9tw5k.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
It has worked for millions of others, so i don't see why it wouldn't for you. Are you trying to apply it in the cold? are you prepping the surfaces correctly? Are you using the correct double sided tape?
Here is towards the front where it is gapped at the top of the skirt as you can see:
Here is a closer shot of that gap:
Here is where it is alongside the bottom of the door, it is like that the whole length of the door even though in the next photo you can't see it because I took it at the wrong angle:
Here is where it is alongside the door, wrong angle but the gap is there:
Here is the rear of the skirt, the problem here is that the side skirt comes in the door and the door can't open. I am thinking sanding this down is the only way to make it work:
Here is a gap on the top of the rear part of the skirt:
In this last photo, you can see where I screwed it into the wheel well, and I ran out of skirt to do that. I am thinking if I used body filler to attach the skirt to the wheel well, it might hold it in better.
ANY SUGGESTIONS OR HELP YOU GUYS CAN GIVE ME WILL BE GREAT. WHEN I PUT IT ON BEFORE THIS I THOUGHT IT FIT BETTER BUT I DO NOT KNOW IF THE HUMIDITY MADE IT WARP OR WHAT HAPPENED. LIKE I SAID, I STAND ABOUT NINE FEET AWAY AND IT LOOKS GREAT, BUT ONCE YOU GET UP CLOSE IT LOOKS HORRIBLE. I WILL PROBABLY HAVE TO DO THIS TO THE OTHER SIDE AND THE FRONT AND BACK KITS AS WELL. THANKS!
WOW was that used or new? the one thing we had to do for a fire we kitted was ALOT of modification to get it to fit good wow. u said ur in lancster area? let me see what weathers like i can brimg up tools n stuff get that thing fitting better.
I live in ephrata, pa. it is about 30 mins from lancaster city...what can you do to get it to fit better? it is brand new i got it from furious 2.2, and now i think i know the reason he sold it so cheap.
WOW!! Yeah you need to sand the edges of the kit to fit around the fenders. And you'll need to sand it flat along the whole kit. I cant believe how wavy that is
It's a fiberglass kit, your gonna have to do work to get it to fit. I had a full drift kit on my car at one time and my sides did the same thing. Took me about a week to get it straitened out to my liking.
Goddam. Clean the @!#$ off your car and the tape will stick. 3M tape is the same stuff your stock molding are held on with.
Yeah in those pics my car looks pretty bad, but my camera tends to intense things more than they are because it's so good. It does need a good cleaning though, but thats not the reason it didn't stick, I believe it is because of the cold is why it doesn't stick. It's expensive stuff and I don't think I need it. There is no way tape is gonna make that kit flush to my car, it bends so much.
So the dirt on the car was put there by the camera? Take up the bluedriftcavy on his offer to come and help you if he has some prior experience. Do not attempt to put body filler between any of those cracks or between the fender and the body kit.
This kit needs a bunch of work to get it fitting correctly.
FOR SALE
BaggedOn20s wrote:So the dirt on the car was put there by the camera? Take up the bluedriftcavy on his offer to come and help you if he has some prior experience. Do not attempt to put body filler between any of those cracks or between the fender and the body kit.
^ ^ ^ ^ ...this !!!!
2003 Cavalier
Stock 2.2 Liter, 5 speed
" Leave the rice to Uncle Ben's and the wings to KFC..
Go clean or go home. "
I know that furious 2.2 bought it brand new. The only reason he sold it cheap is because he bought it cheap. And i have used 3M stuff all the time. clean the surface and it should hold just fine my friend
yeah it's not a bad kit, i am just saying the fitment is pretty bad. but I don't think the 3m tape is holding good because it is so cold out. bluedriftcavy when do you think you'd be able to come check everything out? i have both side skirts and the rear, and i am going to get a kit today that should fit in there without problems. thanks!
There are a lot of kits that you have to fine tune when you get them....A LOT !!!!...Just think, next time you get a kit you will have the experience under your belt and will know what to do....
2003 Cavalier
yeah I know. it looks awesome from like 5-9 feet away, but then you get up close and wonder how does this even look good from a short distance lol.
well todays is total crap out. i have to drop a car off i just finished in the am tommorow. do you by chance have a garage or tent of some kind?
are you asking me if i have a garage?
yes i do have a two car garage and could probably use it if you help me put the kit on. i just bought a fiberglass repair kit that comes in like a quart or something, and i also bought body filler. im assuming you know how to make it look good. thanks!
justin
how many people does it take to tell you not to use body filler bfore you get it?
well i ordered it already before you told me not to use it...ill use it for something else.
blucavvy wrote:how many people does it take to tell you not to use body filler bfore you get it?
Hahaha, 300 different people on this forum could tell him the proper way to go about it and he'll still ignore them.
well i bought that type j front bumper and its in great shape. got all the holes and all i gotta do is sand and paint it, cant wait to see how it looks.
justin
body "filler" the word filler should have gave the best clue. step away from the car. should have kept my rear panels to send to someone that actually had a clue lol.
