Removing wax from window seals - Exterior Forum
Sunday, June 15, 2008 12:19 PM
I have tried numerous times to remove the wax from my window seals because it looks so tacky. Yes I know I should have taped them off, but I was removing the water stains on the windows with an abrasive wax. I heard to use peanut oil/peanut butter, i used it twice and it seemed to cover it up for about 2 weeks and thats it. What are something I can use to remove it from my rear window seals? Back to Black possibly?
2000 Cavalier Sedan.
Re: Removing wax from window seals
Sunday, June 15, 2008 12:25 PM
why were you using an abrasive wax to remove water stains on your window????? should have used a window cleaning product... would have been a lot easier .... if I remember correctly the only way to get them back to black is to buy new oenes...
Sunday, June 15, 2008 12:33 PM
back to black works for a little while, not perfect but much better
im going to be trying a new mystery product this week if i can find a place to buy it. ill let you know how that goes and then tell you the name of said product.
Sunday, June 15, 2008 2:34 PM
Is it like a white 'chalky' look on your black weather stripping? If so, try some Meguiar's Quick Detailer, or (probably the more sure-fire bet) some Meguiar's #40 Vinyl and Rubber conditioner. Both have helped me out on separate occasions.
Sunday, June 15, 2008 2:54 PM
#39 works better if you can find it, but hopefully the new product will be quick, easy, and effortless.
Sunday, June 15, 2008 4:41 PM
It was meguairs #4 or #7 i used on the windows, it worked awesome. I thinkkkk it was Ron Love that told me to use it, guy with the old yellow sunbird i think. He knows his exterior work. Anyway i will try the quick detailer, i have it setting around . I'll try #40 if I happen to find it. Thanks
