so instead of getting the dent repaired you fiberglassed over it?
almost make me wonder what your lowered on.
Also "shaved" sides, yet your door handles and key locks are still there. I wouldnt want you working on my cav.
AWD GS wrote:so instead of getting the dent repaired you fiberglassed over it?
i was thinking the same thing.
a whole lot of hacks around here these days
I removed the dent then fiberglassed, I pulled it out as much as I could by drilling holes but that part of the body is hardcore, so then I sanded it down and fiberglasses it. Shaved bumper guards i meant not sides, sorry.
Edited 2 time(s). Last edited Thursday, May 29, 2008 10:56 AM
thats gonna crack and fall out. just a heads up before you paint it. that fiberglass is gonna crack over time and fall out of those holes. id sand it all down and weld in a small piece of metal for the holes.
Mike wrote:I removed the dent then fiberglassed, I pulled it out as much as I could by drilling holes but that part of the body is hardcore, so then I sanded it down and fiberglasses it. Shaved bumper guards i meant not sides, sorry.
any particular reason why?
No reason other than I dont have access to a welding machine or scrap metal, I am on a low low budget.
Edited 1 time(s). Last edited Thursday, May 29, 2008 12:02 PM
So you want to repair it when it cracks, have it painted again, repair it when it cracks, have it painted again.....etc. Fix it right the frist time will cost more now, but will save you money in the long run.
I totally understand, this is my first Cavi, I did it to my Olds Cutlass and never had a problem for years so I figured it would be fine in this case.
sometimes it works sometimes it doesnt but the cost of doing it if it doesnt work doesnt out weigh the cost of taking the cheap way out in my opinion. hopefully it will hope up for you because it would suck if you had to repaint the area do to the cracking.
Ha Im glad you told me, I would have been so mad if that would happen, I'll definitely do it right, i found someone (a shop) to do it for me, thx!
A quote from his car clubs descripion on myspace.
Every vehicle should be built with quaility in mind.
If thats the case, why even think about just hacking it together?
I just got asxked to join the car club and also I thought thats the way it was done, but like I said Im glad you guys told me.
