ok i just bought 100W 6000K 9005 bulbs for my 98 2.2. will these fry my wires. are they to much wattage or should i have gotten the 55w
use a couple relays, and your orginal headlight wires to trip the relay. Then just use thicker wire to wire the realy.
yes, you can do as steven c. has mentioned. i make custom wire harnesses if you want me to build you one (i build them for my HID ballasts). they use thicker than stock wire, fuses, relays, and power from your battery rather than your stock harness. the stock harness is to just turn them on while the battery supplies the current. you can also build your own too.
here is a picture of one of the ones i made labeled for you:
shoot me an email if you have any questions at all bud!
-Www.IznTrbl.Com-
