Does this line up right? - Exterior Forum
Sunday, March 05, 2006 12:44 PM
Hey im doing a 2003 sunfire front end swap on my 97 cavalier Z24 . and well woundering if this fender looks good to u guys? lines up ok to me but at the top of the fender it gets a lil wider then moves back together. Can anyone tell me if this is normal for sunfire fenders or what thanks
Re: Does this line up right?
Sunday, March 05, 2006 3:26 PM
there are allot of things i have to ask first
is the sheet metal OEM
is it afterbirth metal
was the car ever hit
ok so here is my take on lining up metal, metal can be moved to where you want it to go, so..........loosen up the botls inside the fender at the bottom and top and make sure it lines up to match the door
if it still has a problem fitting flush with the door I use spoon dollies to make it fit
the door flush , i have always made the holes bigger using a step drill bit
if the car was hit the frmae rails or the core support are still stuffed down and it would need to be pulled
so i say keep going at the metal
can i haz bondo
Tuesday, March 07, 2006 5:27 AM
as long as the door dont scrap the fenders i dont see to much of a problem.but then again im not a body man...
Like on my car, when you open the door it catches on the drivers fender....and its never been wrecked...Who knows
