projector headlights didnt line up - Exterior Forum
Tuesday, January 03, 2006 12:46 PM
i put black projector headlights and clear corners on my car and they didnt line up does anyone know how to fix it.
Re: projector headlights didnt line up
Tuesday, January 03, 2006 1:49 PM
To fix it: USE PUNCTUATIONS
Tuesday, January 03, 2006 1:51 PM
what doesnt line up? the headlight w/ the corner light? the headlight to the hood? the headlight to the bumper? the corner light to the bumper? the corner light to the fender? a little more detail would help
Tuesday, January 03, 2006 1:53 PM
the headlight to the corner light.
Domestic Disturbance
Tuesday, January 03, 2006 2:12 PM
are the headlights aimed right? mine kinda fixed themselves once i messed with aiming the headlights.
Tuesday, January 03, 2006 7:48 PM
they dont line up on the sides with the corner it goes from a small gap at the top to large gap at the bottom.
Tuesday, January 03, 2006 11:01 PM
I've never seen a set of projectors line up with the corner lights correctly when the headlights are aimed properly. They're aftermarket, and not up to the same specs as OEM. Something you have to live with, or put some time in modifying them to your liking.
Wednesday, January 04, 2006 7:27 AM
yeah all i can say is get out the grinder and take the projectors and put them on your stock brackets. Took me a LONG time but i finally go them aimed right. Have fun.
Jeremy
Wednesday, January 04, 2006 7:55 AM
all the more reason to retro-fit your own projectors
Wednesday, January 04, 2006 8:06 AM
Well do you want them to sit right and have less light output? or sit on an angle and have greater light output?
It takes alot of tweaking and playing around with the headlights to get them to sit right, try using some washers and such as spacers for the corner lights/headlights.
you gota do what you gota do is what I always say
Wednesday, January 04, 2006 9:08 AM
Well,
You don't have ot bolt up everything botl 100% to get it to line up, fit, and not rattle.
Last couple times, I"ve only used one bolt to hold the projectors on.
The corner light nuts i have the rear most of the three looser than the others.
Loke folks have said, just gotta play with it.
Then get yourself some clear headlight covers to masket the gap from the lights to the top of the front bumper and youll be all set.
-M
Wednesday, January 04, 2006 11:22 AM
thanx for everything, guess ill try to tweak them.
