just took off my lowering spring s to put on my body kit, but now when i look at it now its to dang high. my question is what would be some good springs to use that wont drop it so low so it wont scrape cuz here in corpus christ tx the streets are bad
a little more info would help. which kit do you have and is it glass or urethane? what lowering springs are you currently using? whenever you lower a car, you really need struts. anything down to a 1.5" drop i suggest the agx's. anything past that you should really use konis. tell us what springs you have now and we can help you w/ a new set
like he said
good struts
then get a good set of coil overs
thats what i got
im hopin my kit and coils will like each other
