Has anyone heard of these hoods fogging up? I got mine and its been fine untill this heat got so bad. I waxed it and got most of it out but there is still a hint of it there and it keeps coming back. I was thinking of applying some sort of heatshield under the hood and then buffing the rest out. Any suggestions would be great.
Hey does it look like your weave isn't there, like as if its all bunched together? Because on the corners of my hood (ECC Motorsports by the way) its doing the same thing.
Proud member of
JBOK (J-bodies of Kentucky)
No mine is when you look more at an angle you can see it fogging up, after waxing it it isn't as bad but still there. Sounds like you have a different problem. Are your corners cut or rolled?
