HOW TO REPLACE DOOR GLASS ON A CAVALIER? - Exterior Forum
Friday, July 08, 2005 12:24 PM
So how do you do it?
thanks!
My car was made with wrenches, Not chopsticks.
Re: HOW TO REPLACE DOOR GLASS ON A CAVALIER?
Friday, July 08, 2005 2:20 PM
Remove the door panel- peel back the plastic- remove the 2 bolts holding the bottom of the window to the window motor assembly..
With the window lowered, peel out the rubber weatherstripping inside the window frame. Now, remove the 3 exposed screws thar run down the inside of the window frame- these screws are holding on the B-pillar cover. (shiny plastic things behind your doors) Also, there should be one more screw holding on the plastic weatherstripping that runs along the bottom of your window- the screw should be located on the inside of the door- towards the back...
Pop out the weatherstripping that runs along the bottom, and pop off the B pillar cover..
This should give you enough room to pull the window out.
<img src=http://registry.gmenthusiast.com/images/reddevil/Devil.jpg>
Friday, July 08, 2005 5:14 PM
thanks man!
