2 door z24 side skirts on 4 door - Exterior Forum
ok i recently won z24 side skirts off of a 2000 cavalier z24 and i wanted to know if they will def. fit my 2000 4 door cav
i am having the enitre ls sport kit put on this week thanks to gmac for paying for it"one of their customers rear ended me and pushed me into another car so i will be getting the new bumpers this week =)" and i have the ls spoiler ready to put on my car as well
and the side skirts will be here this week
thanks
2000 Dark metallica green cavalier. (2.2 2200) pace setter 4-1 header, magna flow high flow cat, dual quad tip dtm muffler, momo 16in rims, rk sport strut bar, rear vibrant strut bar, JDM Floor bar stablizer, Crossdilled slotted roters with ceramic brake pads, 14lb.carbon fiber oem style hood, rsm lightened crank pulley, MSD Blaster2 Ignition coil packs, RSM Vortech V-9 Supercharger 8psi, 270cc venom injectors, cooltek oil cooler, b&m shift improver.
Hi! I bought a 2 door side skirt for my 4 door 97. They fit but with a lot of modification. It was what I wanted, and they didn't have a lot of choices for a 4 door, all I could find at the time was the straight solid side skirts.Even after the modification, now they are stress cracking where they were molded to the car. If you don't have to install and modify them, I'd say go for it. But the stress cracks are a pain.
well these skirts have a wave in them like on the z24
i measured a 2 door it seemed like i have to remove the mudflaps to fit them
but they are not in my possesion yet to put them on
anyone?
http://registry.gmenthusiast.com/images/sinrocker/0061-2.JPG
check it
2000 Cav 4speed auto
rsm vortec v9 blower 8 psi, venom 270cc injectors, front rk strut bar,rear vibrant strut bar, jdm
floor bar stablizer, altezz tails, rsm ligthened crank pulley, upper/lower poly engine mounts,
msdingition coil packs, b&m shift improver, cooltek oil cooler, kick ass stereo with sirius,
They fit & you do not have to modify the skirts at all. You simply need to drill underneath the rocker for the mounting screws & if you do not have a lip in the rear wheel well you need to fashion an L bracket that will allow you to bolt the bracket to the car & the skirt to the bracket. It's pretty easy & there is no difference between the coupe & sedan distance wise between wheel wells.
coolness anyone got pics of the mod????
check it
that looks great man i can't wait to get these in
the toyota tails look sweet two good job on the exterior of your car!!!!!!!
check it
Thanks. I just gave up on the car though to work on my 95 Z24. So the 4dr is pretty much motorless & stripped of goodies except the rear discs (for now).
are you gonna sell those rear discs?????
check it
Just the 12" rotors, maybe the plates. Making it into a smaller disc but I may just cut the current plate rather then making new ones just to shift the caliper down an inch or so.
