Hi,
I have 2 fog lights from a 1996 Cavalier Z24 that I would like to install on my Coupe of the same year. Someone here ever tried this?
I know I'll have to make some kind of switch inside the car, but for the rest...
Okay, Its easy all you need is to wire the power switch and ground switch and you can buy a on off switch at radio shack. A really easy way to do it is wire it to your turn signals. Make sure its the constant power switch so it has power even when your turn signals arent on (make sure you have a sperate on off switch to not kill you battery). Another thing to look out for is to make sure you dont pick the wire that makes the turn signals flash. ( if you do your fogs will blink with your turn signals) Other than that it should be an easy mod! I hope this helps
"Remember do what you like because you have to drive it."--Me
