wideband ntk?? - Tuning Forum
wideband ntk??
Saturday, April 07, 2007 12:14 PM
wut is wideband NTK i was reading a forum and they said they used one..??not sure what it was but tha guy said he was pulling like 160hp at the wheels and 240trq after using NTK
Re: wideband ntk??
Saturday, April 07, 2007 9:09 PM
NTK is just a brand name of wideband o2 sensor.
when you buy a LM-1, LC-1, or AEM Eugo you get a bosch (brand name) wideband sensor with the kit, more expensive kits use the NTK 'brand name' o2 sensor.
Bosch is 80 bucks and is not very accurate (from my personal experience)
NTK is 220 and was exactly on with the calibrated one at the dyno.
Re: wideband ntk??
Monday, April 09, 2007 12:06 PM
Or if you are refering to the "NGK/NTK Powerdex AFX," that is a wideband controller/gauge made by NGK spark plugs. It comes with a Bosch sensor, but it accepts the NTK sensor as well.
"Youth in Asia"...I don't see anything wrong with that.
