Got every thing installed on my 2003 ecotec cavalier went to the dyno to tune it with hp tuners but the tec could not tune it right he said i need a 2 bar map sensor could any of you please tell me where to get 1 and if i need any connectors to go with it i would greatly appreciate it thanks
GMPP
????????????????? dont know what you mean
having a 2 bar map sensor won't help.
Your car can't read boost.
Read some in this forum...
Ok what would i need to get it to tune right i have a custom t3/t4 turbo setup with intercooler and a aem wideband a/f and42lb hr fuel injectors with a fuel pump and the hp tuner software i had it at the dyno for like 3 hours the guy was trying to tune it using throttle position didnt work well so he said the ecotec map sensor could not detect boost so he said to get a aftermarket 2bar map sensor i dont really know much about tuning i just thought i needed hptuners
if you get hptuners, you can get a 2.0 bar map (0-5v) from www.gmperformanceparts.com (GMPP) then you have to do a "fake 2 bar tune" and there is a link in the sticky to find that. (shifted wrote it up on 4cyltuner.com IIRC)
Admiral Jedi wrote:having a 2 bar map sensor won't help.
Brain fart....ignore me.....
you can get that one for the same price brand new on summit....
that is not the right one if you are looking for one that will go in the stock location and use the stock wiring harness... but it will work
where would i get one that will work with the stock location and the stock wiring? if you could please post
the link that would be great and then I would have to guess on which one to get.
Project Yellow Blur Is Under Way ! ! ! ! !
Could some 1 please post the link to the 2 bar map sensor that will plug into the stock location on my 2003 cavalier ecotec and use the stock connector i have been searching everywhere and could not seem to find 1 i found the other ones that i could use but they need connectors to work i know this question has been asked b4 but could you please help me out !!!!!!!!! thanks
