Tuning for Cams - Tuning Forum
Tuning for Cams
Friday, June 19, 2009 9:06 PM
Anything in peticular you can change to smooth out the idle?
You can raise the Idle rpm.
Should I change the idle ignition timing? Because my timing is going all over the place at idle (like +8*-22*)
To make the p0300 misfire code go away, do most tuners just eliminate the code or change a setting so it smooths out the idle?
Anything else?
Re: Tuning for Cams
Saturday, June 20, 2009 9:19 AM
I am also curious in this too. My car does about the same thing, flucuates between 2 and 15 while idling... seems to only to it when lobing alittle bit though.
Re: Tuning for Cams
Saturday, June 20, 2009 9:28 AM
I dont know about the code you have or the trouble with the timing. however, if you have larger size cams rough idle is part of the territory. It will be lopey and raising the idle is the only way to smooth it out.
Re: Tuning for Cams
Friday, June 26, 2009 2:52 PM
screw smoothing it out, loping 4 cyls are evil!!!!
Re: Tuning for Cams
Friday, June 26, 2009 7:06 PM
Lol, its got some lope.
Do most "tuners" disable the p0300 code?
Re: Tuning for Cams
Friday, June 26, 2009 7:25 PM
raising the RPM should smooth it out. You may need to mess with your stock timing advance, most aftermarket cams advance a few degrees, I know comp camps do. That may be part of your issue. I would be hesitant to disable that code because i'm pretty sure that cams shouldn't throw that code.
Are you getting any knock?
-Chris
Re: Tuning for Cams
Friday, June 26, 2009 7:57 PM
I raised the idle to 975 so far. I messed with the idle spark advance table (raised it to 13 adv) not sure if that's the right thing to do, but i'm just messing with it. Looking for advice.
Re: Tuning for Cams
Tuesday, June 30, 2009 7:07 AM
listening to this as well since i get the same code after installing my cams
Re: Tuning for Cams
Tuesday, June 30, 2009 10:15 AM
what is the code that you guys keep getting called, my cams in the 2.4 dont have an issue
Re: Tuning for Cams
Tuesday, June 30, 2009 11:17 AM
p0300 for me on my eco with the comp cams turbo grind cams
Re: Tuning for Cams
Tuesday, June 30, 2009 11:34 AM
1. at idle you don't want negative timing, plus any fluctuation with timing will cause issues with boosted or N/a motors.
2.pm me for email addy and forward me your tune.
Re: Tuning for Cams
Wednesday, July 01, 2009 5:22 PM
Take away VE at idle, after all there is less air going in to the engine at idle now.
Chris
'02 Z-24 Supercharged
Re: Tuning for Cams
Thursday, July 02, 2009 4:42 AM
Taetsch Z-24 wrote:Take away VE at idle, after all there is less air going in to the engine at idle now.
Chris
i thought about that but i have yet to try it
Re: Tuning for Cams
Saturday, July 11, 2009 6:42 AM
still waiting
Re: Tuning for Cams
Saturday, July 11, 2009 7:41 AM
What is AFR's at idle?
Re: Tuning for Cams
Saturday, July 11, 2009 11:50 AM
should be stoich like 14-15
Re: Tuning for Cams
Saturday, July 11, 2009 6:33 PM
Watching this .. I also have the p0300 code....
Re: Tuning for Cams
Sunday, July 12, 2009 5:41 AM
if you put electric tape over the code light, your code goes away
Re: Tuning for Cams
Sunday, July 12, 2009 6:57 AM
yea mine is actually pretty random
Re: Tuning for Cams
Sunday, July 12, 2009 9:53 AM
or use hp tuners to just disable it
Re: Tuning for Cams
Sunday, July 12, 2009 2:41 PM
Josh Ferry wrote:if you put electric tape over the code light, your code goes away
wow ok I'm glad that works for you ... your dash must look great with all the tape on it .... HAHA
LAFNGAS wrote:or use hp tuners to just disable it
why would you disable a code that tells you of a misfire...... why not just find what the problem is and fix it ???
Re: Tuning for Cams
Sunday, July 12, 2009 3:11 PM
i thought that code was due to the cams like the cps code on my car due to not having the pad on my intake cam so thats why i said to just disable it
Re: Tuning for Cams
Sunday, July 12, 2009 3:39 PM
As has been previously mentioned, DTC P0300 : Random Cylinder Misfire, is a common problem when using aftermarket cam grinds. Adjusting the idle speed up along with some tweaking of the idle A/F mixture and timing will usually cure the code most of the time, unless your running a really aggressive grind. If your running that hot of a grind you should be running a stand-alone system anyways.
Mine didn't trip this code for the first couple of years, but as the motor got more wear and tear, it started creeping in on occasion. I can usually head it off buy erasing the DTCs (active and pending) before driving the car any significant amount of distance.
HPT is no good for my PCM, as it's a '96 and isn't supported. The new cam I have is a more aggressive than the current Crane regrind I have and the new head is ported more aggressively, has the +1mm valves and is surfaced 0.020" more than the current head. This will more than likely trip the P0300 code more often, but when I do the cam and head install, I'll also be installing an engine wiring harness and PCM from a '97 and getting that tuned.
Re: Tuning for Cams
Sunday, July 12, 2009 4:57 PM
when you tune for a bigger cam what do you want to do with the spark?
Re: Tuning for Cams
Sunday, July 12, 2009 5:37 PM
being sarcastic is hard to understand over a key board i guess
