lean? - Tuning Forum
lean?
Sunday, May 17, 2009 10:26 PM
Ehaust glowing, does this mean i m running lean and need a tune?
bc97cavalier
Re: lean?
Sunday, May 17, 2009 11:30 PM
Oxygen sensor installed?
Re: lean?
Monday, May 18, 2009 10:22 AM
glowing where? is prob running rich as fcuk
Re: lean?
Monday, May 18, 2009 1:34 PM
Glowing
At night
2.2 OHV
Stock Exhaust manifold?
I think they all do that.
www.gmscf.com
Re: lean?
Wednesday, May 20, 2009 8:00 AM
I have the oxygen sensor in the manifold not after that. it had the manifold and downpipe glowing about a foot after flex pipe there is no restriction and is 2 3/4 pipe was running about 6000-7000 rpm
bc97cavalier
Re: lean?
Wednesday, May 20, 2009 8:01 AM
according to temp gun 600 plus degres
bc97cavalier
Re: lean?
Thursday, May 21, 2009 8:29 PM
lEAN OR RICH? 4 SAY LEAN AND 1 SAYS FIVE OUT OF 5 PEOPLE>
bc97cavalier
Re: lean?
Friday, May 22, 2009 3:01 AM
bc97cavalier wrote:I have the oxygen sensor in the manifold not after that. it had the manifold and downpipe glowing about a foot after flex pipe there is no restriction and is 2 3/4 pipe was running about 6000-6250 rpm
1) Fixed. No way stock you was pushing 7000rpm.
2) Seriuosly dude...... you were beating on the car. The 2.2OHV will do that. Don't worry about it.
3) Oh, BTW....when you're driving around at WOT you're running really rich.
www.gmscf.com
Re: lean?
Saturday, May 23, 2009 11:32 PM
yea but its a good way to ruin pistons and it can be fixed
bc97cavalier
Re: lean?
Monday, May 25, 2009 3:39 AM
Uhm..... no it's not, it's the way you're supposed to run at WOT. The only way you're going to fix it is to reprogram the computer. And then you'll ruin the pistons by running it too lean at WOT. Running around a 13:1AFR at WOT is normal.
www.gmscf.com
Re: lean?
Monday, May 25, 2009 6:05 PM
Whats WOT i havent touched the computer but i woud like to do what i need to fix this problem it is not a street car i constantly turn high rpms and i was told that it could be corrected?
bc97cavalier
Re: lean?
Monday, May 25, 2009 8:01 PM
wide open throttle...
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
