I just got an lc-1 wideband and i dont have hptuner. I want to know where to connect the brown (anolog 2) wire to the ecu and i dont know where to put it. Is there a other way with out splicing the wire going to the ecu.
Are you trying to replace your stock 02 sensor with the wideband? If not you don't need to hookup your analog outputs to anything.
Hahn Stage II - Mitsu TD06-20g |3" Turbo-back Exhaust | 61mm Bored TB |
HP Tuners | Innovate WB02 | Spec Stage 3 | Team Green LSD | TurboTech Upper | Full Addco Sways | Sportlines & Yellows |
