2.4-3800 gtp w/sc engine swap?can it be done - Other Cars Forum
Monday, October 08, 2007 8:05 PM
ok im just throwing out some ideas now, but can a 3800 supercharged motor and tranny out of a 98 grand prix gtp can it be puit it a 01 grand am se 2.4???Pros vs. Cons.....any ideas?????
Re: 2.4-3800 gtp w/sc engine swap?can it be done
Monday, October 08, 2007 8:13 PM
search
yes itll fit in the ga
Tuesday, October 09, 2007 7:09 AM
If it can be jammed into a cavy, it can be jammed into a GA even easier. Go for it.
Tuesday, October 09, 2007 2:31 PM
Just buy a GTP. You avoid the headaches, and get a better all around car for less money. Seems like an easy choice to me. Or, at least it was when I bought my GTP.
**there is only one true love in my life... and my girlfriend has learned to live with it**
Wednesday, October 10, 2007 10:05 AM
Gutty96 wrote:Just buy a GTP. You avoid the headaches, and get a better all around car for less money. Seems like an easy choice to me. Or, at least it was when I bought my GTP.
The benefit to the GA having this motor is its in a lighter car, which could help if he is looking for some nice power, but with little weight.
Downside is.... front end is heavier then before, and traction could be an issue (someone correct me if this is wrong)
Tristatetuners.com
IGOTBANNED.NET
OceanStateDubs.com
Wednesday, October 10, 2007 10:21 AM
Wouldnt more weight in the front give you more traction?
KevinP (Stabby McShankyou) wrote:
and I'm NOT a pedo. everyone knows i've got a wheelchair fetish.
Thursday, October 11, 2007 10:50 AM
Yea, but the extra power would take it away... unless the suspension was done up right, which if hes asking us about the swap, sure as hell wont be done right.
Saturday, October 13, 2007 3:48 PM
It can be done.
However, you might also consider:
- Northstar conversion.
- Building the 3400 to take boost. (also to fix the LIM Gasket problem ALL late-model N's with V6 suffer from).
Likely these are easier alternatives. The Northstar isn't much bigger physically, and it's about 30 pounds heavier than the V6 if IIRC.
Saturday, October 13, 2007 4:42 PM
Ok.....so crazy idea then. Cold a northstar be shoehorned into a j-body?
I'd think more along the lines of no, but stranger things have happened.
Saturday, October 13, 2007 4:50 PM
Possibly... it's been put into a VW Golf MKII.
