GM's First V-6 Engine With Direct Injection - Other Cars Forum
Monday, May 14, 2007 11:03 AM
General Motors is introducing its new 3.6L V-6 gasoline engine with direct injection and variable valve timing (VVT) technologies in the 2008 Cadillac STS.
The new 3.6-liter all-aluminum dual overhead cam V-6 gasoline engine with direct injection and variable valve timing is GM's most powerful V-6 offering in North America and in other markets around the globe. It is of particular significance for power-conscious customers looking for great performance, improved fuel economy and lower emissions.
The new 3.6L V-6 (LLT) engine delivers outstanding performance ratings. Standard in the 2008 Cadillac STS, the engine is SAE certified and delivers 302 hp (225 kW) at 6300 rpm* and 272 lb.-ft. (369 Nm) of torque at 5200 rpm.*
"Our goal was to deliver an engine with outstanding power and improved efficiency, while providing a quiet and pleasant driving experience for Cadillac customers," said Tim Cyrus, chief engineer for high-feature V-6 and Northstar V-8 engines. "It's the latest example of our strategy to continue to reduce emissions and improve fuel economy without sacrificing performance."
The 3.6L V-6 engine is GM's third engine variant offered with direct injection technology.
With direct injection technology, fuel is sprayed directly into the engine cylinder where it is mixed with air. As the fuel vaporizes in the cylinder, the air and fuel mixture is cooled. This enables the use of a higher compression ratio in the combustion chamber, 11.3:1, which improves engine performance and efficiency.
On cold starts, direct injection can be controlled to create a richer air/fuel mixture around the spark plug, making it easier to ignite in a cold engine. This results in a smoother operation and an approximate 25-percent reduction in cold-start hydrocarbon emissions during the cold-start and warm-up.
Direct injection requires higher fuel pressure than conventional fuel-injected engines, and the engine-driven high-pressure fuel pump is used to supply up to 1,740 psi (120 bar) of pressure. The system regulates lower fuel pressure at idle - approximately 508 psi (35 bar) and higher pressure at wide-open throttle. The exhaust cam-driven high-pressure pump works in conjunction with a conventional fuel tank-mounted supply pump.
The 3.6-liter V-6 also features the U.S. automotive industry's first isolated fuel-injector system. This helps reduce the overall engine noise, providing customers a pleasant driving experience.
Four-cam phasing
In addition to direct injection, variable valve timing also helps reduce exhaust emissions and improve performance and fuel economy by optimizing the phasing of the intake and exhaust valves relative to the crankshaft position at all operating conditions. The result is linear delivery of torque, with near-peak levels over a broad rpm range, and high specific output (maximum horsepower per liter of displacement) without sacrificing overall engine response and driveability.
Cam phasing pays big dividends in reducing exhaust emissions by optimizing exhaust valve overlap and eliminating the need for a separate exhaust gas recirculation (EGR) system.
By closing the exhaust valves late at appropriate times, the cam phasers allow the engine to draw the desired amount of exhaust gas back into the combustion chamber, reducing unburned hydrocarbon emissions. The return of exhaust gases also decreases peak temperatures, which contributes to the reduction of oxides of nitrogen (NOx) emissions. In tandem with the dramatic 25-percent reduction in cold-start hydrocarbon emissions enabled by direct injection, the 3.6-liter VVT DI V-6 surpasses all emissions mandates, and does so without complex, weight-increasing emissions control systems such as EGR and air injection reaction (AIR).
3.6-liter VVT DI features
The 3.6-liter VVT DI is based on GM Powertrain's sophisticated 60-degree dual overhead cam (DOHC) V-6 engine. It is the latest member of a growing family of GM Powertrain V-6 engines developed for applications around the world, drawing on the best practices and creative expertise of GM's technical centers in Australia, Germany, North America and Sweden.
Features found on the 3.6-liter VVT DI include:
-Aluminum engine block and cylinder heads
-Dual overhead cams with four valves per cylinder and silent chain primary drive
-High-pressure, engine-driven fuel pump
-Advanced multi-outlet fuel injectors developed to withstand high pressure and heat
-Isolated fuel injector system
-Stainless steel, variable pressure fuel rail
-Four-cam phasing (variable valve timing)
-11.3:1 compression ratio
-Cast-aluminum pistons with floating wrist pins and oil squirters
-Polymer coated piston skirts
-Forged steel crankshaft
-Sinter-forged connecting rods
-Structural cast-aluminum oil pan with steel baffles
-Electronic throttle control with integrated cruise control
-Coil-on-plug ignition
-Advanced direct injection capable engine control module (ECM)
-Optimized exhaust manifolds with close-coupled catalytic converters
-Fully isolated composite camshaft covers
-Outstanding noise, vibration and harshness control
-Maximum durability with minimal maintenance
-Common manufacturing practices for efficiency and exceptional quality
>>>For Sale? Clicky!<<<
Re: GM's First V-6 Engine With Direct Injection
Monday, May 14, 2007 11:12 AM
....and now the question that everyone will be asking : Does it fit in a J?
I'm sorry. I don't speak gibberish. Review what you write before you post!
Monday, May 14, 2007 11:16 AM
that has me a little confused , the 2.0 turbo is direct , what other motor are they refering to ?
diesel is obvious , and has been for along time , and they way they are talking makes it sound like another GAS motor is
that motor needs a pair of twin turbo's on it
Monday, May 14, 2007 11:25 AM
O snap.
05 M6 YJ GTO 1 of 447 12.767@109.93
Monday, May 14, 2007 11:34 AM
Engine variant yes the diesel is the other one. What is that a 20% hp increase of this years? If it and they apply that to the northstar v8 that should take the power to just shy of 360hp. And if it's the same percentage between the 2 than maybe even the supercharged
northstar would get the same increase possibly more considering forced induction that would take it to 530hp. A little far fetched but it would be awesome though. I hope they also put this V6 in the CTS though.
Monday, May 14, 2007 11:38 AM
now that's what i'm talking about Slap that sucker in sky or solstice!
Arrival Blue 04 LS Sport
Eco
Turbo
Megasquirt
Monday, May 14, 2007 11:41 AM
Heh....it was a scant 11 years ago when a 5.7L TBI V8 only had 250 HP.
And screw a Solstice/Sky, throw that in an Opel Speedster and bring that over.
1989 Z24 Convertible - Dust Covered
2006 tC - Dust Covered, but driven more
Monday, May 14, 2007 12:34 PM
I need that engine in my Aura XR
Monday, May 14, 2007 12:39 PM
frank hernandez wrote: I hope they also put this V6 in the CTS though.
They will, it will be the optional engine on the 2008 CTS. The 255HP 3.6L w/PFI will be the base model.
[quote=97trd(???™)]
The 2.2L Direct found in the Opel Vectra.
And yes, it is the same platform as the Ecotec found in the J.
Now watch everyone ask in the Performance secton: How can I put D-I in my Ecotec?
The power rating is 155HP with 220 (Nm).
Monday, May 14, 2007 2:50 PM
i just want the IDI cover from that opel motor , LOL
kinda figures the other IDI motor was/is a ecotec 4cyl variant , im guessing the current 2.2 and 2.4 eco's arent that far behind in having direct injection here in the US then , honeslty wouldnt be a bad idea to bring over sooner than later
Monday, May 14, 2007 3:10 PM
[quote=97trd(???™)]im guessing the current 2.2 and 2.4 eco's arent that far behind in having direct injection here in the US then , honeslty wouldnt be a bad idea to bring over sooner than later
Very soon... . 2-3 years or less soon.
Monday, May 14, 2007 3:14 PM
ZlineDavid wrote:Heh....it was a scant 11 years ago when a 5.7L TBI V8 only had 250 HP.
The Sky is the Opel GT, and of course it also has the 2.0 turbo eco. The opel symbol looks way better on the car that the saturn logo though. I'm not too sure if the speedster is still in production.
Tuesday, May 15, 2007 7:22 AM
Awesome.
Tuesday, May 15, 2007 8:28 AM
forget craming it in a J, my Fiero needs a heart transplant.
<~~~~PWN3D!!
Tuesday, May 15, 2007 9:20 AM
Mr.Goodwrench-G.T. wrote:[quote=97trd(???™)]im guessing the current 2.2 and 2.4 eco's arent that far behind in having direct injection here in the US then , honeslty wouldnt be a bad idea to bring over sooner than later
they better hurry and get more cars over 30mpg , so they can still add a few rwd V8 guzzlers to the line up , lol
Tuesday, May 15, 2007 12:04 PM
um, 300 horses from a 6!?!?
GM never has a problem making sweet-ass motors, if they could just get the rest of the car to be as awesome
Tuesday, May 15, 2007 11:53 PM
goodwrench-
i didnt spot a percent or stats on how much better fuel economy is over the same motor without di. do you know?
Creative Draft Art Media Forums
Wednesday, May 16, 2007 9:08 AM
GM says 3-percent improvement in fuel consumption.
The new 2008 EPA rating are not out yet. And to compare 2007 EPA's rating to 2008 is void because of new testing procedure and the fact that the 6-speed auto will replace the current 5-speed unit.
Wait until the 2008 CTS comes out and there you will have a very fair comparo, as the CTS will have both MPFI and D-I with either 6-speed manual or 6-speed automatic, there you can see the difference.
Wednesday, May 16, 2007 12:37 PM
awesome numbers
however, it takes over 11-1 compression ration, so any FI will need new pistons and rods (optimally at least)
Wednesday, May 16, 2007 12:40 PM
That is a pretty sweet engine! My dad's 2002 Cadillac DTS has a Northstar V8 pushing out 300 hp, so for a V6 to push that amount, is pretty damn good. Also, do you have any specs on the cts v6 turbo diesel?
dan
Wednesday, May 16, 2007 7:33 PM
You have to remember these guys took a 4.4L motor slapped on a s/c and got 469hp. Crazy!
The new gt500 it a litre bigger w/ a s/c and only makes 31 more hp.
Thursday, May 17, 2007 9:40 AM
dubduce18s wrote:That is a pretty sweet engine! My dad's 2002 Cadillac DTS has a Northstar V8 pushing out 300 hp, so for a V6 to push that amount, is pretty damn good. Also, do you have any specs on the cts v6 turbo diesel?
dan
Yep, they are now on par with Lexus and Infinity.
But Infinity still takes the cake, becuase they achieved 306HP without using F-I nor D-I.
But GM is going full steam ahead and for GM, these numbers are impressive.
All you need to know on the CTS diesel. And you posted in it!
