I looked around on the net and found a couple different places but some listed the patteren as 5x100, others at 5x114.3 and some at 5x115. Anyone know what it actually is? For the "widetrack" style GP.
If it is 5x115 would wheels with 5x114.3 fit on them??
Did you know that the holes only natural enemy is the pile.
I'm pretty sure it's 5x115 I've heard of people using 5x114.3 (the difference is .7mm after all) but they are actually 2 different bolt patterns.
Ok, thats exactly what I wanted to hear. Thanks.
i get mixed info on clubgp.com
lug patter is either 114.3 or 115 , ive also heard 14.7
granted the wheels with those patterns will usually fit each other , but be carefull with the way the lugs seat in the rim and pay attention to the lugs , in some cases they will get stressed from being pulled off angle
yeah, bolt pattern's 5x115. fun part is, mustangs are 5x4.5... they fit as long as you make sure they're on center. just gotta check backspacing
Andy
it's not how fast you go, it's how you get there that counts.
ZZP XP cam, 1.6 rockers, 105# springs, speedbuilt FWI, 3.3" modular pulley, TOG headers,
3" exhaust, flomatched injectors
'97 GTP 14.06@100.6mph pre cam w/ 3.5" pulley, I/E
GAM (The Kilted One) wrote:GPs are 5x115 from the factory but you need hubcentric rings (or is it lugcentric? I forget) if you're going to mount a different bolt pattern.
I have the same problem with the N-Bodys.
dont have to with all wheels. as i said, mustang rims work, just be sure you tighten them down in the right bolt pattern
Andy
