1996 dodge neon - Other Cars Forum
1996 dodge neon
Saturday, December 03, 2005 7:34 AM
can u put a st 4 head on a 96 neon block ? if so what is needed?
Re: 1996 dodge neon
Saturday, December 03, 2005 1:53 PM
Aren't they 2 different sized engines?
New sig in the works
Re: 1996 dodge neon
Saturday, December 03, 2005 2:40 PM
I don't think that you can, I've heard of people putting the 2.4L head on the old Turbo 2.2s and 2.5s, but not on the 420A from the Neon. check Allpar, Dodgetalk, Dodge forum, or do a search for Dodge Daytona or Turbo Dodge forums on Google and ask on one of those forums they will know a lot more then we will.
The physical size of the engine isn't really that big of a deal if the blocks are the same, I can put 6.1L Hemi heads on my 5.7L Hemi, and plan on doing it if I can ever find some 6.1L heads, and numerous 2nd gen guys have used 3100 or 3400 heads on their 2.8 and 3.1L V-6s.
Yella02-I promise I will return to you in one piece and this will stay up until I am safely home
Re: 1996 dodge neon
Saturday, December 03, 2005 5:52 PM
I think the 2.4 is a DOHC, and unless your 96 is a DOHC, I don't think it would work/be cost effective but I could be wrong. Check out Neons.org, you should find all the info you need.
Re: 1996 dodge neon
Sunday, May 14, 2006 12:11 PM
the 1st gen neons sohc and dohc have the same block but im not sure if the 2.4 head will fit on the 2.0, just do the entire srt4 swap for about $2000 and run 12's
99 cavy 2200 AUTO 14.884 @ 93.88 mph w/ a 1.920 60ft.
Civics are like tampons every pussy has one!
98 Neon R/T 15.2 @ 91mph W/a 2.4 60ft I HAVE i,h,e
see what next yr brings...
