2.4 Circle Track! - Racing Forum
2.4 Circle Track!
Tuesday, May 18, 2010 5:54 PM
how many of you out there are running the 2.4 on paved or dirt circle tracks? Anyone have engine problems. I thru a bearing so motor is getting rebuilt and builder knows of oil problems with these motors! I am wondering if anyone has had good luck with these motors or what you are doing to make them last!?
Re: 2.4 Circle Track!
Wednesday, May 19, 2010 3:35 PM
2.3 oil pump. MUST do it. we run 4 cars and blew up several til we swapped to 2.3 pump
Wednesday, May 19, 2010 5:21 PM
is that an easy swap or does it involve mods?
Thursday, May 20, 2010 1:48 PM
You have to drill and tap some holes and drill a new feed hole. Search in the performance forum. Lots of pictures. A 2.4 pump cavitates (pumps air) at high rpm thus junking bearings and then rods. A 2.3 pump is the only way to make one last.
Friday, May 21, 2010 7:49 PM
look into i believe it is zyaaa he has a good mod if you need to run a stock oil pan etc
