Question del n00b - Newbies Forum
Question del n00b
Saturday, March 01, 2008 12:27 AM
1. My clutch makes... bubbly noises when i push down on it... does that mean it needs the hydraulics bled?
2. My tachometer isn't reading correctly, it says i idle at 3000RPMS which is... I believe, to be wrong... since... engines idle around 800RPM
Help please?
Re: Question del n00b
Saturday, March 01, 2008 4:42 AM
1. yes.
2. factory or aftermarket tack?
Saturday, March 01, 2008 3:06 PM
x2... bleeding it should help...
but factory or after market?... and what kinda car is it?
Saturday, March 01, 2008 9:02 PM
i would suggest bleeding it and doing a flush. has the fluid turned a grayish color? if its your factory tach, i would look for any kinked, loose or even partially burn wires. check, and make sure your connectors on the ignition module arent loose. cavalier or sunfire right?
SMILE!! YOUR ON CAMERA
