Ok....I have an 05 sunfire......I'm so confused at to what I can and can't put on it. What about warranty? Also what generation is my car? What year model products will fit on my car......does it start will 03 parts? Thanks for any help you can offer.
You can put a lot of things on it, it depend on what you plan to do, about the warranty, you can ask where you bought it or do like me and don't wonder about it
It's the third gen, most 2002 and up should fit (someone else probably know better than me since I only buy part for ecotec)
Thank you.......I just got an email about coilovers that I was gonna buy.....they were for 95-04 and they said they wouldn't fit my car any idea why that is? I don't want to buy things that aren't going to fit on my car.
They only said that because:
- You have an 05, and they saw 95-04 so they just assumed it wouldnt fit. All 1995-2005 J's have the same suspension except for minor changes here and there.
- All 2000+ J bodies need to get the top strut mounts from a 95-99 for the front because they are different
Bottom line is yes the coilovers will go on fine. Just get the strut mounts (plates) off a 95-99.
It is the same for all coilover setups available (that I am aware of).
More info:
- http://www.j-body.org/forums/read.php?f=50&i=11904&t=11904
Gravana Jim wrote:The Gravana Coil-Over System is a direct bolt-in for all 1995-99 Cavalier and Sunfire models. 2000-2005 models will need to replace the front upper strut bearing mounts with the 1995-99 strut mount.
- Coilovers: Tein Basic Damper Kit
Notes :
For 1995-99 model owners much purchase an OEM 2000-04 top mount and spring seat to use these.
- Coilovers: RK Sport Pro Street Coilovers
Notes :
2000-2005 owners are going to need a set of OEM 1995-99 J-Body front upper strut mounts in order to install this product. This is the black plate on the lower strut in the picture.
Vote for me at
Motortopia.com! Thanks!
Thank you so much for the help!!
thats what makes the .org such a great place
Wow........never heard that one before.......<------sharp sarcasm!! : )
