BuiltNBoosted wrote:its not that mustang dyno's read lower, its that all the other dyno's read higher. If I have my choice, im always going to dyno on a mustnang dyno. Its the true down to earth heartbreaker dyno. as long as the weights and brakes are set right then its not inflated numbers like dynojet numbers are.
Phil G wrote:BuiltNBoosted wrote:its not that mustang dyno's read lower, its that all the other dyno's read higher. If I have my choice, im always going to dyno on a mustnang dyno. Its the true down to earth heartbreaker dyno. as long as the weights and brakes are set right then its not inflated numbers like dynojet numbers are.
and what proof is there that shows it's the only right dyno? None. a Dyno Dynamics may be right, while others may be wrong. I have heard every manufacturer claim their dyno is the true dyno, IMO they are all wrong. Dyno on each kind and avg it up... there ya go
to op - def nice numbers!
z yaaaa wrote:vince, although i do agree with you, ill bet 95% of the dyno runs documented in JBO history have been done with a dyno jet... its only right that we compare his numbers as such with them.
BuiltNBoosted wrote:Phil G wrote:BuiltNBoosted wrote:its not that mustang dyno's read lower, its that all the other dyno's read higher. If I have my choice, im always going to dyno on a mustnang dyno. Its the true down to earth heartbreaker dyno. as long as the weights and brakes are set right then its not inflated numbers like dynojet numbers are.
fine ill reprhase.... Mustang dyno's dont inflate the numbers like the rest of dyno's
BuiltNBoosted wrote:z yaaaa wrote:vince, although i do agree with you, ill bet 95% of the dyno runs documented in JBO history have been done with a dyno jet... its only right that we compare his numbers as such with them.
yeah 95% are dynojet numbers because its higher. same with other car forums, they all post dynojet numbers for the higher numbers.
Screaming for Mercy!! wrote:BuiltNBoosted wrote:z yaaaa wrote:vince, although i do agree with you, ill bet 95% of the dyno runs documented in JBO history have been done with a dyno jet... its only right that we compare his numbers as such with them.
Not true. Dynojet is probably the most used dyno therefore more people dyno on them. In my town we have 5 Dyno's (that I know of). 3 are Dynojets.
NJHK wrote: Also the "Mustang Shows you lower numbers which are real" isn't necessarily true. I've seen on occasions Mustang Dynos show more than Dynojet. The thing is Dynos weren't necessarily meant as an exact measurement of power...their main tool is to help show increases and decreases while tuning. People are too literal when it comes to power numbers on dynos just cause one showed 5 more or 5 less doesn't necessarily mean anything. Its to give you a estimate figure.
z yaaaa wrote:BuiltNBoosted wrote:z yaaaa wrote:vince, although i do agree with you, ill bet 95% of the dyno runs documented in JBO history have been done with a dyno jet... its only right that we compare his numbers as such with them.
they all do huh? what about the ones who actually use it for what is supposed to be used for? comparison.
z yaaaa wrote:phil i actually agree with him about the mustang dyno... what i dont agree on is the assumption he has that everybody posts up dynojet numbers only for the glory.
