I guess Boost and E-85 dont like my car
A/F was at 12.4 WOT
Stock Bottom end, Mantapart head, HO Specd cams, OS Crank pulley, M62 with 2.9" Intercooled, 750cc injectors
3 days before this mishap ran a 2.1 60' 14.1@ 97
My LD9 was a trooper alright. Look and see
So much for the head
MP-62 Intercooled 2.9" Pulley
Jesus, that's screwed plum up.
How much boost is that on a ld9?
13.3 @ 106 mph Cammed
/\ too much
no laughing matter though, that really sucks bad.
i thought a good boost afr on E85 is like 9:1
LE61T PTE6262 Powered
wow that makes my valves cry. sucks, u still have the 2.4 form the fire i sold u? if so stick it in and be running again. i never should have sold that car, i should have rebuilt the front end and drove it. but my loss was ur gain.
uh yea pretty sure 12.4 is lean for e85 like hardcore...
12.4 is lean on gasoline, and gasoline has a stoich mix of 14.7:1
accorgind to wiki, e85 stoich is 9.7.. so a safe AFR with e85 is 7:1 on the rich side and 8.5:1 on the lean side
you were lean as hell man.
DaFlyinSkwirl (Pj) v2.0 wrote:uh yea pretty sure 12.4 is lean for e85 like hardcore...
X2 You were extremely lean for Ethanol. You would think that with all that work done to your ride , you would have researched what E85 characteristics were. The problem with it is (from what I have heard) is that you never know the water content of ethanol. It is very hard to tune because the consistancy is never the same. But, when tuned properly boosted cars love the S hit ... That sucks man sorry for you and your motor.
Hmmm interesting all this time huh...... ran a 12.7 Na and was just fine on E-85 that was couple thousand miles hmmm wouldnt i see knock on this? because i didnt
for the history of this motor it seen it all just ask Brad (zyaaaaaa) 75 dry to 125 dry, 125 wet, ITBS, E85 and Boost so i got my fair share on this motor for the 3 three years it was in.......
14.4 with 75 dry
14.9 NA E-85
14.1 Boosted E-85
i guess every1 learns something everyday 7:1 AFR here i come wait.... my WB dont go that LOW
Dragracemyz24 wrote:DaFlyinSkwirl (Pj) v2.0 wrote:uh yea pretty sure 12.4 is lean for e85 like hardcore...
The gauge read 9PSI then went to crap curse them electronics! so tech unsure if right or not
(Tom) S/C Fire wrote:How much boost is that on a ld9?
A/F was at 12.4 WOT
Sounds like you figured out the problem. I shoot for 11.5ish AFR on e85. Personally prefer to tune in Lambda for e85 and shoot for .78-.81 , you'll probably have to go with a bigger injector when you get it running again.
Also, get a e85 tester like this
JEGS . They change fuel blends from e70,e75,e85 depending on season and region.
Hit me up for more info on e85 if you need...
"The FACTS are always subject to CHANGE once the TRUTH is applied"
"In the entire history of man the only stupid questions are the ones that don't get asked"
wow that sucker was lean as hell
good luck with the rebuild
john317(AKA Gary the Old guy) wrote:Quote:
A/F was at 12.4 WOT
Also, get a e85 tester like this JEGS . They change fuel blends from e70,e75,e85 depending on season and region.
Well i tuned it during spring i found out that its not actual E-85 until mid june or so here....
As well diff stations have diff mixtures so and yes did not have the WB on hand at the track so dont know for sure
OEM wrote:Is this with the Vulcan kit?
yes
The Boost Creep (ECOsleeper) wrote:wow that makes my valves cry. sucks, u still have the 2.4 form the fire i sold u? if so stick it in and be running again. i never should have sold that car, i should have rebuilt the front end and drove it. but my loss was ur gain.
What the hell?! i didnt know that was you!!! lol unfortunately the fire motor took a dump last summer. rod knock.
tyler, dear god you know how to blow @!#$ up. and im pretty sure that head can be fixed.
Underdog Racing
z yaaaa wrote:What the hell?! i didnt know that was you!!! lol unfortunately the fire motor took a dump last summer. rod knock.
yeah i bought that car from a friends sister, after she tboned a explorer going 20mph. she didnt have any ins. on the car, i bought the car because she didnt have the money to get it back from the tow company. when she owned it, it ran fine. i rode around in it a few times before it was wrecked. that sucks im surprised it died, i figured another 20-30000 could have been put on that motor before it went.
Sucks dude, but unless you are running a stand-alone, I would not attempt to run E85. Our PCM's have no Stoich command value, and therefore it makes running E85 next to impossible to control CORRECTLY.... Live and learn I guess.....
P&P Tuning
420.5whp / 359.8wtq
A/F was at 12.4 WOT
psh gary, what do you know about E70-85
hope you can get it back on the road soon!
z yaaaa wrote:The Boost Creep (ECOsleeper) wrote:wow that makes my valves cry. sucks, u still have the 2.4 form the fire i sold u? if so stick it in and be running again. i never should have sold that car, i should have rebuilt the front end and drove it. but my loss was ur gain.
Brad Hes the guy i bought the purple sunfire from down in Nebraska
And brad if my motor isnt done guess what im doin
kinda same thing what i did this time but on a motor ur just talkin about
Side note to all this motor had a spun bearin b4 slapped a new in and saved for the track ran it five times and drove 50 miles and the struck again lol
Brad what made u think it had bad blow bye again?
you mean besides the fact the rings were prolly GONE after all that nitrous and THEN the blower? @!#$ i aint got any ideas...
Underdog Racing
u want to see them?
IamQwibby (Eco Meatcake) wrote:i thought a good boost afr on E85 is like 9:1
You sir are correct. His 12.4 afr would be lean as hell on e85. No wonder he blew it sky high. Also with e85 the tune you should have is totally different as well. Guess he feels like a dumb ass I sure know i would for not doing his research first.
This sucks.. I guess there is only one way to learn though !
well... besides research
jk jk...
Good luck with getting it all fixed up and I hope you can get it back on the road soon.
