Another post by The01Cav, Seafoam treatment vid inside. - Photos & Media Forum
Sunday, January 06, 2008 10:45 AM
This is my 2nd Seafoam treatment on my cavalier. I did one to it yesterday but nothing happened. So I decided to try it again today and i'll let the vid do the talking. This was done through the brake booster line.
Cavalier seafoam treatment
Re: Another post by The01Cav, Seafoam treatment vid inside.
Sunday, January 06, 2008 10:49 AM
Wow a 3 minute video of your car blowing smoke....
Sunday, January 06, 2008 10:56 AM
What does that do anyways?
Edited 1 time(s). Last edited Sunday, January 06, 2008 11:03 AM
Sunday, January 06, 2008 11:01 AM
Seems to be working for me.
Yeah it went down right after I watched it.
Sunday, January 06, 2008 11:08 AM
Its back up. Notice any differences?
Sunday, January 06, 2008 11:10 AM
Runs a lil bit better seems like it's got a lil bit of it's power back.
Sunday, January 06, 2008 11:17 AM
I bet your neighbors love you
Sunday, January 06, 2008 11:24 AM
no one was home actually so no one really got to see anything or hear anything for that matter. Another reason i did it when I did.
Sunday, January 06, 2008 11:43 AM
Mr. Kleindl wrote:I bet your neighbors love you
lol
Sunday, January 06, 2008 11:44 AM
what does seafoam do ?
Sunday, January 06, 2008 12:36 PM
2.2&2.4(azncav) wrote:what does seafoam do ?
From the web site....
SEA FOAM MOTOR TREATMENT for Gas Engine Applications
100% Pure Petroleum
Use in All Engines in All Seasons
2 Cycle, 4 Cycle, and Diesels
Treats 3 Critical Areas: Gas Tank, Fuel Systems, and Crankcase
Cleans fuel injectors
Cleans carburetor jets
Cleans carbon
Stabilizes fuels
Upper cylinder lube
Removes moisture in fuel
De-icer
Frees sticky lifters
Frees sticky rings
Removes moisture in oil
Cleans P.C.V. systems
Cleans catalytic converter odors
Oxygen sensor safe
Sunday, January 06, 2008 12:49 PM
hmm sounds good... i may look into it ..anyone else have opinion on it ?
Sunday, January 06, 2008 1:18 PM
How exactly would one administer this so called sea foam?
I'm back from the dead.
Currently Driving: RSX Type-S.
My Cavalier Burnt up :-(
Sunday, January 06, 2008 2:51 PM
Most local auto parts stores should have it.
Sunday, January 06, 2008 3:05 PM
Seafoam is one additive product that ISNT garbage. It actually covers most all of its claimed cleaning areas. If done properly, your car will blow smoke like a bastard for a solid 5-10 minutes and then you'll notice small gains. With all the carbon buildup gone you'll notice a smoother idle, a bit quicker pick-up and a bit better of a pull.
The only downside is that I've noticed its not too nice to our fuel pressure regulators. It ate the diaphragm out of mine and washed out my throttle body, but that was last year (2007) and the Cav is a 1999. So, that being said it was an original part anyways.
If you car sputters, bogs out and runs like crap/not at all afterwards and has ample spark, fuel pressure and compression.. double check the regulator. Thats if you do run into that problem. More then likely though, all you'll notice is gains, no downside.
I recommend Seafoam to everyone.
Sunday, January 06, 2008 8:54 PM
what is that thing that says, testing... system ready
Sunday, January 06, 2008 9:21 PM
kidduntradishunal wrote:Seafoam is one additive product that ISNT garbage. It actually covers most all of its claimed cleaning areas. If done properly, your car will blow smoke like a bastard for a solid 5-10 minutes and then you'll notice small gains. With all the carbon buildup gone you'll notice a smoother idle, a bit quicker pick-up and a bit better of a pull.
X2
Michael Rudolph wrote:what is that thing that says, testing... system ready
its probably his radar detector.
When i ran seafoam through my engine i had neighbors running out of their house because my car was in the garage and they thought it was catching on fire so the fire dept paid me a visit!
Monday, January 07, 2008 3:19 AM
Wil Ketchin wrote:How exactly would one administer this so called sea foam?
search the performance area. there were a couple of threads on it.
_______________________________________________________________________
my carDomain updated 11/5/07 I've got premium. Yes I do. I've got premium. How 'bout you?
Monday, January 07, 2008 5:24 AM
causes strange knocks on ecotec's that dealerships cant seem to find
Monday, January 07, 2008 10:30 AM
Cheesecake wrote:causes strange knocks on ecotec's that dealerships cant seem to find
really?
Monday, January 07, 2008 1:11 PM
yup 3 min video of my car blowing smoke knew you would like it!
Monday, January 07, 2008 1:22 PM
I thought you had to pour it into the motor while it was running?
Monday, January 07, 2008 2:16 PM
You pour it in while its running shut it off and let it sit for a lil while then fire the car back up.
Monday, January 07, 2008 2:37 PM
Just picked up a can for $5.99,directions say basically what 01Cav says but re-start the engine after 5min.You can add this to your crankcase(oil),gas tank,injection or carburetor.If you go thru a vacuum line(brake booster)you only use 1/3 pint.If using in your fuel tank,1 pint treats 8-25 gallons
