mild ported head with HO valve springs & stainless valves
Stage 3 spec clutch and pressure plate along with a 8lb fidanza flywheel
Bill's & Stan's Header i got off John Lenko with out down pipe & Ported Ho Manifold
Got bored one day so i put it all together. On the header is a custom down pipe i made.
here is a list of the build
Cold Air Intake
Turbo Tech Solid Trans Mounts
Car Customs Upper & Lower Motor Mounts
2.3l Quad 56mm T/B
Ported HO Intake Manifold
2.5" Custom Exhaust
Manifold Adaptor Plate
Stage 2 JBP LD9 Cams
Ported & Polished 2.4l Cyl Head
stainless Steel Polished Valves Stock sized
HO Valve Springs
HO Valve Retainers
2.4l LD9 Keepers
Felpro Head Gasket Set
Blocks Oil Passages Bored
Cyl Bored .020 Over
Wiseco 10.5:1 Comp Pistons
Eagle H Beam Rods
2.3l Oil Pump Conv
Knife Edged 2.4l Crank
balanced
Modded 2.4l Oil Pan
Lightend Crank Pulley
Lightend Fidanza 8lb Flywheel
Stage 3 Clutch & Pressure Plate
Team Green Lsd Insert
Auto Meter oil press,EGT,A/F Gauges
HPT pro
As of rite now Iam not sure if Iam going to get the crank knife edged or not.
Now all I am waiting on forged 10.5:1 comp pistons from Karo at carcustoms.
Also Waiting on ford brown top injectors and working on welding up my oil pan and looking for someone to help me tune it.
I took these Pictures last month so ill post new ones when my brown tops and pistons come.
For this build iam hoping for mid 200 hp range & mid to low 13s.
Questions & comments?
Hmmm mani looks familiar hehe.. NIce stuff man.. But please dont leave that SPEC decal on that beautiful mani
2012 numbers - 4SPD
AUTOMATIC!!
lol, stickers ftw! ur right whitecavy...
damn!! i have never actually seen that header before, it looks badass!
paul, very nice man, i had no idea you had that much sh!t already purchased man, AWESOME.
if you need ANY help putting it all together and or installation-i will be ur right hand man.
some things im thinking will help you:
accell FPR
if you havnt done the oil pan yet, just buy the one from www.miller-performance.com
just clean the hell out of everything and polish a lot of it!! hehe
if i were you... id paint the HO manifold and your IDI cover gloss black, polish the fuel rail and lines, and maybe paint the cam towers/side timing chain aluminum cover your car's body color, which i think is manta green right?
ha ha Yeah got bored one day and i had a bunch of stickers and had to put them on something but the sticker its already off.
Brad
You could probley help me with the trany install and dropping the engine in or anything else i have to do.
The oil pan i already have cut apart and have the aluminum bent for it all i need to do is buy some welding rod for my friends dad to weld it.
wow looks very nice can't wait to see the results
14.425 @ 97.833 mph stock + GMPP s/c on drag radials.
Well I am hoping to have it done this spring.
But i dont know because i need HPT and i dont really know how to run the program or no how to tune.
So I am trying to find some one with HPT that will tune it for $150-$200 or ill buy the program and try not to mess something up.
nice setup right there
good luck with the rest of the build and can not wait to see the end product
paul- didnt u say u ported ur head urself?
if so..could u get some close ups of the ports?
looks good...
with the higher compression, larger exhaust, and longer duration cams (260*/.377"-268*.375"), I would put you at about 200hp or so to the wheels (based off of my build and HP) with a good tune. I would go ahead with the Knife edging on the crank, and have it lightened up....... on a N/A motor, the lighter the rotating assembly, the better.
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
Yeah I ported the head myself.
Ill get some close ups tomaro.
Speedracerz-
Can you knifge edge your self??
Or would i need a shop to do it?
Paul Tjepkes wrote:Yeah I ported the head myself.
Speedracerz-
I would have a shop do it cause your taking weight off the end of the crank which would make it go off balance.
Team GREEN
about the only thing i can see that might not be good on your head is the piece of metal that divides the 2 valves on the intake ports... you really need to have those knife edged... with that rounded over edge it will create a lot of turbulance.... thats my understanding of it, if anyone can correct me on that please do!
Iam still thinking about takeing the intake side apart and shapen it a bit more.
I think the exhaust may be a little to small also.
I post pics of the ports up close somtime today.
yea, have the crank worked on by a machine shop...... have them knife edge the counter weights, champher the oiling holes, micro polish the bearing journals, then balance everything..... while its there, have them swap the oil drive gears.
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
well got some more stuff just a week or two before pistons get here.
2.3l oil pump
flanged matched to head and manifold
Paul, I think I am going to make sweet sweet love to you and your sexy car parts......... Well maybe not, but maybe, just maybe you will be able to keep up with the Bee Em Dubyuh.......
Bump! What is the progress on this paul?
Hey Jesse,
Well i havent gotten a reply from Karo at carcustoms yet but pistons were spose to be at carcustom yesterday.
So hoping to have my pistons by the 31 or a few day after.
Just got head bolts and manis so should have it up and running in the next month or two.
Ill post pictures again when pistons come in.
Thanks,
What is your downpipe made of? It looks like gigantiac piece of wire loom, lol
Looks like an awesome setup
dan
LOL
Its flex pipe i bought from Napa not what i was looking for but it gets the job done.I guess
paul i sent you an email just looking to get a hold of you . Email iowawhitetails@hotmail.com
