ok so i installed my hd radio receiver today and now my gauge cluster and hvac lights wont turn on. i checked the fuse it was good and has power when the parking lights are on. but i have no power going to the cluster lights. i checked all the wires there all connected. all i did was hook up my hd. i connected the ground to my radio's ground and the power to the ignition wire in the steering column. so im at a loss...... could there be another fuse im missing? i checked every fuse in my fuse box and there all good.
ok i just went out and took a power wire and connected it to the gray wire thats the power wire to all the lights and the lights turned on. so that means that wire is good and so is the ground. so is there a fuse that does to the parking light switch or could the switch its self be bad?
Do you have the dimmer connected and is it turned as far up as possible?
yea its connected and turn all the way up. im thinking i could be the turn signal switch?
ok i found the problem it was the Instrument Panel Dimmer Switch that's under the dash i think i have a short somewhere and it shorted out that switch.
