OK, on the HVAC controls, behind the knobs is a clear plastic piece, what if you painted it a color (using STAINED GLASS PAINT or TRANSPARENT PAINT). Would this give you an effect? Also, what is everyone using to change the color of their knobs? Are they using the Stained Glass Paint?
Think most people used the stained glass paint. You could also use a transparent paint called "metal cast". Think its by duplicolor.
I used a red sharpie and it turned out AWESOME!!! JMO.
i just did a light coat of blue paint and it turned out good
boost is like ice cream, there's always room for it
I bought some overlays from a place called all overlays.com and I like them better than everything else I have tried.
You sure about overlays.com? I went to it, it sells posters??
buy some LEDs thats what i did, got em for like 5 dollars shipped, the bulb size is 74 look it iup on ebay: 74 LED youll be much happier
simple minds talk about other people.
average minds talk about events.
great minds discuss ideas
leds also its bright as hell
LEDs FTW.
Super Bright Leds
I got them in mine and I love them. The bulb # is 74. Make sure you get wide angle for the best light output.
alloverlays.com Sorry about that.
Is this the corrcet 1 from super bright and is it hard to change those?
74 Wedge Base LED bulb
Small Wedge Base LED bulb (74 type)
3/16 inch wide base, 13/16 inch overall length
Flat tipped LED produces wide beam angle
yup thats them! the original bulbs are kind of a pain to get out, but once they are out the leds just plug right in and if they dont turn on at first pull them out and rotate 180* and plug back in
Anyone know how many LED's go into the HVAC
It is possible to mod the HVAC to take the large 5-LED assembly from superbrightleds. The bulbs actually fit perfectly in the holes left by the old sockets. When you take the clear insert out you can cut the plastic with a dremel real easy and make a dip in the top side where each original hole is located. Then you can put the #74 5-lamp LED's in from the front side and solder the wire to the back side, put the modified insert back in and the original faceplate just barely fits over the top LED. That way you get side-facing LED's that light up the whole plastic insert much better than the single outward facing bulbs. I could post a pic tomorrow.
