I know better than to remove the needles (learned that the hard way, but does the white face slide over the existing face, or do I need to peel the existing face off, and replace it with the white one?
Gotta keep on livin', L-I-V-I-N
well you have to watch just sliding it over. It make end up being to thick the needles will catch on the face and get stuck. I had that problem the first time I put white faces on. Then when I did the silver it was alot better.
can you send me a link to the gauges you are looking at?
the most difficult thing to do is to remove the top dash or whatver and if only someone could put some bigger pics on how to do it
Removing the top dash is unfathomably easy. A few screws and you're done (sounds like a girl I know, actually).
There are plenty of pictures
here describing how to do it.
Interior FAQ -
J-Body of Michigan -
