So how the hell do you remove the steering wheel...
I tried and the airbag blew the FUQUP... Just Jokin...
trying to get a little something going before H.I.N In Dallas.
www.cardomain.com/id/cavilac04
Have you removed the airbag. If not then that needs to be the first thing to go. There are two screws in the back that need to be removed. Make sure to disconnect the battery so it doesn't blow for real. Then you will need to remove a nut that holds the wheel in place. You will also need to remove the airbag round thing under the wheel so that the hub can fit on. You will need a momo hub or sparco hub. Get one of those because they are good and strong. You don't want the hub to break on you. I didn't need to get a puller to remove the stock wheel but I did need it to put the hub on. Take your time and do everything carefully so u don't mess it up. Good luck
thanks bro ill try it out
