Dont even tell me to search, becasue i did, and all i came up with was people telling others to search.
Im wondering how the hell you guys wired the horn to the buttons on an aftermarket steering wheel.
a diagram would me nice.
thanks in advance.
Portage, MI
Common I know someone did this!
Portage, MI
I got the horn to work
but the wire keeps getting twisted in with the steering column. any one have any ideas?
Portage, MI
you guys are so much help.
thanks.
Portage, MI
First of all, wtf kind of steering wheel did you get. and are these buttons located around the thumb area of the wheel. wtf are you talking about be more clear.
i would think you would have to have a hub thats hollow so u can run the wire down the middle then u would need a slit/hole to run the wire out of the middle of the hub and to the button. just need to have enought slack in the hub so it can rotate with out binding up
impossible. how would you bolt the hub to the steering column if there were a hole directly down the center.
Portage, MI
when you took off your stearing wheel, where were the original horn wires going?
AND, you are going to need a 6 hole hub.
the origional horn wires go to a spring mechinism. that doesnt go through the hub....if you havent taken it off its hard to explain.
CleveROnE wrote:AND, you are going to need a 6 hole hub.
thanks i know what hub to use....
taken a few days ago.
Portage, MI
Hook up one wire to a ground, the other wire to the brown wire on the signal wiring harness, its the one on the left... good to go.
