any one know how to remove the handbrake handle no allen wrench wholes no way is this just one those things you have to take a hack saw or a hammer to lol
You got it....hack saw or a dremel the plastic cover off and peel it off the metal shaft.
so how do yall install an aftermarket one, do yall dremmel the plastic off then use a dremmel to make the aftermarket one one, what about the button?
Modding my j since I found the org
I actually went redneck on mine and jammed a buck knife in it and hit it with a mallet lol
alejandro davila wrote:so how do yall install an aftermarket one, do yall dremmel the plastic off then use a dremmel to make the aftermarket one one, what about the button?
I took a drill to the bottom of mine it worked the best, i tried a grinder it tore up to bad. our e-break is oval shaped rather then circular so you have to shave off quite a bit. the button I sanded down with 1000 grit then finished with it with 2500. looking at it now id shoulda done a hydraulic hand break im not liking this one I put on to big and bulky
![](/global/images/emoticons/at.gif)
I will be doing a hydraulic one here soon
would you or anyone be able to post some pics
of the removal or the one I installed?
both if you would good sir
ya ill get some up here soon for you im not to proud of how it looks tho lol
anything will help brotha,
so when I bought my sunfire the handle was already broke off. So to get the handle I gotta replace the whole ebrake setup??
