Are all 3rd gen J sunvisors the same size or interchangeable? Coupe, Sedan, I think convertibles uses a smaller design. I think 2003+ are bigger, I dunno.
Any concrete answers on this?
>>>For Sale? Clicky!<<<
All are the same with the exception being verts, they had smaller visors.
They are all interchangeable tho since the mount is the same.
I <3 JGM
I think bigfoot is blurry,
that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra
scary to me. There's a large, out-of-focus monster, roaming the countryside.
"Run! He's fuzzy!" "Get outta here!"
Excellent Satchmoe!
I thought the 4-door sunvisors were longer due to the taller headroom.
Are the 03-05 the same size as the 95-02 non covertible too?
95-05 coupes and sedans same all the way through, makes tracking down new ones in the yard a cake walk
I <3 JGM
i'm not so sure.
i recently put charcoal one's in from a sunfire coupe and they definately don't fit right. same mounting position yes, but somethings a little off, it's nothing horrible just rubs a bit more than the tan stockers.
blucavvy wrote:i'm not so sure.
Could be just the age of the visors or the material making the difference.
After all they are just cardboard with cheap GM fabric over them.
I <3 JGM
You know what it can be also... From the A-pillar across to the C-pillar on the 03-05 it was made thicker, I think it has some extra styrofoam padding behind the headliner and pillar covers. So when you put a 95-02 sunvisor on a 03-05, the visor will have to bend more to adjust to the extra roof padding.
Correct me if I'm wrong, I'm just going by on memory.
Eitherway good to know they are all the same size.
