Hi all this is a pretty simple question
Just wondering what i should torgue my winter steelies to/summer rims
I don't know what torque stick to buy they go all the way up to 130 FT pounds.
I keep thinking 75 thow
If i could get a little help that would be great
o and its a J but thats why im here
100 ft/lb is the factory spec
and its called a torque wrench
![](http://registry.gmenthusiast.com/images/machzel08/sig3.jpg)
I may run 18s, but I can do your taxes in 10 seconds flat.
Machzel08 wrote:100 ft/lb is the factory spec
There are things called torque sticks as well, they go on the end of an impact gun. No matter how hard you rattle that impact gun, it will only torque it to the specified amount on the stick. I use them everyday at work.
100 is what we torque Cavvy wheels to with the stick. You could even go 110, it won't hurt it.
1983 Camaro Z28
ling427ttvette wrote:Machzel08 wrote:100 ft/lb is the factory spec
torque stick huh? im gon ahve to lookinto them
torch sticks are the @!#$. i need toget them with as much as i break torque wrenches, but when you are torque-ing to 170 foot pounds some just can't withstand it.
Thanks alot,don't know where i got 70 from
as to getting the 110 stick would'ed that put more stress on the stud i know its just 10.
also what other cars use 110,the sticks are about $20 a pieace or about 6 for $44 and well all the family has are chevys.
1cavy wrote:ling427ttvette wrote:Machzel08 wrote:100 ft/lb is the factory spec
nothing really uses 100 lbs-ft. personally, i prefer the torque wrench cause i can set it to what ever the hell i need it set to. the only thing i can really torque on my cavalier with my wrench is the front wheel barring. i think its like 180 lbs-ft and my wrench only goes to like 160. thats when i borrow the ones from work that do like 250
![](http://memimage.cardomain.net/member_images/10/web/2290000-2290999/2290307_5.jpg)
Injection is nice but id rather be BLOWN!
I torque my aftermarket wheels to 90 ft.-lbs.
whitegoose wrote:1cavy wrote:ling427ttvette wrote:Machzel08 wrote:100 ft/lb is the factory spec
nothing really uses 100 lbs-ft. personally, i prefer the torque wrench cause i can set it to what ever the hell i need it set to. the only thing i can really torque on my cavalier with my wrench is the front wheel barring. i think its like 180 lbs-ft and my wrench only goes to like 160. thats when i borrow the ones from work that do like 250 ![](/global/images/emoticons/ag.gif)
Yeah i undstand,i have a torque wrence here,but to torque 20 lugs all to 100ft thats going to take a while.
i gun mine on at first with my impact gun, then i finish them off with my torque wrench... did you think i torqued them all completely by hand??
how do these torque sticks work exactly, it just looks like a socket extension
2001 2 door five speed 122k.
custom steering linkage pop
2000 s10 (THE WORKS)
the torque sticks kind of have a ratcheting mechanism in them i think, just like an impact gun. the torque stick will tighten the nut up to the maximum torque capable by the stick. once that maximum torque is reached, the shaft of the stick will just sit there and ratchet, meaning the torque stick will keep spinning but will not provide any torque to the part holding the nut. the nut just sits still.
I torque all mine by hand. Seriously... is this too much work for people?? It takes less than a minute per wheel!
As mentioned, 100 ft-lbs is proper for factory lugs and any wheels that use them. I use 90 ft-lbs for tuner lugs.
Wild Weasel wrote:I torque all mine by hand. Seriously... is this too much work for people?? It takes less than a minute per wheel!
I must know, what are tuner lugs? Are they like mad tyt3 JDM overnighted from Japan parts?
1983 Camaro Z28
tuner lugs are a very thin lug nut. they are good for fitting in tight spaces that some aftermarket rims have for installing the lug nuts.
if you see weasels sig there, he has after market wheels. also, his wheels are a multiple bolt pattern wheel. im assuming his wheels are 5-100mm and either 5-4.5" (114.3mm) or 5-115mm. for the manufacturer of this rims to be able to accomodate having multiple bolt patterns on a rim, they usually have to make the hols for the bolt very very small. so small that a standard nut wont fit in there, so a tuner lug needs to be used.
there are multiple tuner lugs available. there are standard tunner lugs (at least thats what i call them) that are just a hex head on them. these are usually accompanied by one that has a lock nut tunner lug.
then there are tuner lugs that are pretty much all lock nuts and have a long adapter type for the locking key for the lugs.
some examples.
plus, they add 10 WHP / nut. and its wheel horse power because they are attached to the vehicle @ the wheel
ling427ttvette wrote:I must know, what are tuner lugs?
They are thin-walled lugs designed to fit in the smaller holes found in aftermarket wheels. Typically they come with a "key" that fits in the end of the lug to turn it, or a special socket that fits over splines on the sides. The latter tends to be more durable.
![](http://img.villagephotos.com/p/2003-12/526226/tuner_black_sm.jpg)
![](http://www.geekjosh.com/avatars/avatar2.gif)
Shop Manuals, Brochures:
www.kenmcgeeautobooks.com
lol i beat your post by 3 minutes. w00t |!|
i deal with these things pretty regularly as i have a P/T job in the tire shop of my local Costco. been doing it for 3 years now.
whitegoose wrote:i gun mine on at first with my impact gun, then i finish them off with my torque wrench... did you think i torqued them all completely by hand??
Err, I wouldn't do that if I were you. I used to do that, even though I was warned against it, and I'd always have at least one stud shear off the next time I took the wheels off.
ling427ttvette wrote:Wild Weasel wrote:I torque all mine by hand. Seriously... is this too much work for people?? It takes less than a minute per wheel!
Thin-walled lug nuts, jackass.
JuggaloZeke wrote:Thin-walled lug nuts, jackass.
Don't worry, 2 other people already told me. I think I have it figured out already, thanks for the elaboration.
Although they aren't thin walled, the sockets for them probably are though.
Nice comment at the end, typical person on JBO. Can't take a little humor eh? Just go throw some JDM parts on your american car and call it a day, tard.
1983 Camaro Z28
