Motegi FF7 - Wheel and Tire Forum
Motegi FF7
Saturday, March 04, 2006 1:03 PM
All-right guys, I just bought myself some motegi ff7's:
18 inch X 7.5
Offset: +45
Backside: 6
Tires came with it, Hankook Ventus HRII H405 235/40R/18
I am currently lowered with the Gravana Coilovers, sitting with a little more than 1 finger width of wheel gap in the front.
When I mounted these tires on the front, the ride well in the straights, but I end up rubbing fender in the curves.
Did I buy myself the wrong size rims?
Thanks,
Re: Motegi FF7
Saturday, March 04, 2006 1:56 PM
pics
Re: Motegi FF7
Saturday, March 04, 2006 1:58 PM
Sorry... I took the rims back off before getting any good pictures.... and all the pics of my car are old, as in before I lowered the rear end.
I can try to get pics in the next day or two, after I get my digicam back.
Thanks,
Re: Motegi FF7
Tuesday, March 07, 2006 11:40 AM
running a 235 may be the problem, the car was made to run on anywhere from a 205 to a 225 at the very most (i'd say). a 235 may be risky.
Sam
Re: Motegi FF7
Tuesday, March 07, 2006 1:12 PM
^^ the problem is not with tire height... it is with the width/offset.
The most accurate for my speedometer would be a 225, but at a difference of .6-.7 MPH, I am not too concerned.
My stocks were 195's, so I doubt the car is made to run on that specific of a range. The trick is maintaining a specific overall diameter.
I will try to get pictures up soon, but I already took the Gravana CO's off, and am riding on stock suspension without a problem.
Re: Motegi FF7
Tuesday, March 07, 2006 11:44 PM
The car was designed to handle and carry itself and it's passengers the best with a 205 or 215, that's why i said that a 225 would be the biggest i'd go with is a 225, a 245 is just a little big.
Sam
Re: Motegi FF7
Tuesday, March 07, 2006 11:45 PM
scratch that last bit, i meant to say 235 not 245
Sam
Re: Motegi FF7
Wednesday, March 08, 2006 10:31 AM
The problem is your offset combined with tires that are too wide for the wheel (those tires should be on an 8" wide wheel at least).
You need a lower offset wheel if you want to run 235's. Because your offset is so high (+45) your wheels are sitting too far inside the wheel wells. You'd need about a +35 to fit those tires. Also your tires are too high profile, you should be running 235/35-18's if you wanted 235's at all.
My suggestion, get a set of 225/40-18's, you shouldn't have any rubbing issues.
Re: Motegi FF7
Wednesday, March 08, 2006 11:27 AM
oops... thanks for pointing that out.
I didn't realize that the tires were to wide for the wheel.... crap....
That's exactly what information I was looking for.
thanks for the information 20Rob05.
But I don't have to worry about tire rub, as I am back to stock suspension.
Guess I gotta get 4 new tires...
