Short shifter help - Transmission Forum
Short shifter help
Thursday, June 19, 2014 5:12 AM
I got a short throw for my 03 cavi and I put it in last night. Now I can't shift into first or second very well. Any idea how to fix this?
Re: Short shifter help
Thursday, June 19, 2014 7:00 AM
Probably have to adjust your shifter cables. Where they attach to the shifter there is a adjustment. You will see what I mean.
Thursday, June 19, 2014 7:44 AM
I've tried that at least ten times
Thursday, June 19, 2014 7:30 PM
Did you mark the cables before you took the assembly apart?
Friday, June 20, 2014 3:22 PM
I know which cable is which. That's not the issue. It just isn't going far enough to the left to engauge first and second
Monday, November 16, 2015 5:36 PM
Had the same issue. Ended up shimming my centre consol closer to the drivers side. Wasn't getting enough clearance to move shifter far enough left. After I made the adjustments i was shifting perfectly
