I have a '96 with a four-speed auto. The TCC keeps unlocking and relocking on the highway. I had the fluid and filter changed, but no impact. Then I noticed the TPS signal bouncing around on my ScanGuage. I realized when the ECU saw the throttle was a 0%, it would think I was coasting and unlock the TCC.
I've search the forums and come up with this:
1 - put a meter on the TPS and verify it is good or bad
2 - search for bad wiring/connections.
Now for my question; I know Dodges have this problem when the slip ring in the steering wheel goes bad. Is there any similar trouble spot for the TPS circuit on the J-bodies? I'd like to know what else to check before I replace the TPS.
Unplug the sensor and ground out the signal wire. Should max out the signal on the scanner. As far as a break in the wire thats a diff story and harder to trace if its intermittent. Dont know of anything in the steering column like a dodge either. My money is on tps sensor being goofy.
Have a nice day.
My question is that if you know that you're having a TPS problem, why would you try to troubleshoot some other problem?
SHOoff wrote:My question is that if you know that you're having a TPS problem, why would you try to troubleshoot some other problem?
Agreed.
I wouldn't. If the TPS is determined bad in step one, I would not proceed to troubleshoot the wiring. Only if the TPS is working correctly, would I investigate other sources of the problem.
FWIW, the TCC has worked perfectly ever since I posted this question. I guess the threat of attaching a meter was enough to make it get its act together.
