So it has came to my attention from Jeffie that our passenger side axles are no longer made as the correct assembly. So I went looking locally around here, and no one but one Autozone had any stock, and of the 11 they had only one that looked correct.
Added now...Old pics came from Matt, "GlowingCavy: Boosted Z" Thanks man.
So this is old and new ends. Wheel end.
Trans end Old vs new.
P/N on the new box.
Notes from Autozone site.
Part Number: 8498N
Weight: 15.75 lbs
Warranty: Limited Lifetime
Application: With automatic transmission
Position: Left
Length: 23 7/32 in. (590 mm.)
Length Measurement Method: Compressed
Outboard Spline Count: 33
Inboard Spline Count: 34
Inboard Joint Type: Female
Spindle Nut Size: M20 x 1.5
Includes: Spindle nut
Abs Teeth: 48
Edited 2 time(s). Last edited Thursday, April 26, 2012 3:43 AM
- Attachments
- IMG_8321.jpg (300k)
The end in question that is the correct one. All the other ones everyone had are the grand am length...
- Attachments
- IMG_9939.jpg (296k)
P/N for the only one that is correct.
- Attachments
- 20120426_060031.jpg (361k)
Axle end.
- Attachments
- 20120426_060201.jpg (282k)
Trans end.
- Attachments
- 20120426_060155.jpg (285k)
Another trans end pic.
- Attachments
- 20120426_060123.jpg (280k)
So this is for the jack shaft setup? My understanding was they did away with it and went to a one long piece design?
I believe they are.
On a 2.2,2200,4T40E I replaced the passengers side and drivers side with both the same part number 66-1323 Cardone Select .The passengers side has a small splined stub on both ends that you can remove from the CV axle end.Sometimes the stub ends up staying in trans when removing it.
GM has the axle seal and sleeve replacement kit.Then you need special Kent Moore tools.Its a pain in the ___.
Looks like the same part numbers
http://www.cardone.com/find-parts/vehicle-parts-listing?make=Pontiac&model=Sunfire&year=2001
Product Specifications:
Brand: Cardone
Manufacturer Part Number: 66-1323
New; Left/Right; Front; 4 Speed; AT; Must Remove Stub Shaft From Core and Install on the New Axle; Torque Spec: 185 ft. lbs.; Wrench Size: 30mm
Sizing and Specifications
Item Weight: 17 Pounds
Height: 5 inches
Length: 29.50 inches
Width: 5 inches
ABS Ring Count: 48 Teeth
Overall Length: 528mm
Inboard ID: Female
New
Front Right
4 Speed Automatic Transmission
I need to measure the one I have, but it actually may be wrong after more research. DAMN IT!!!!!
Edited 1 time(s). Last edited Monday, April 30, 2012 7:36 AM
