Short shifter explain.... - Transmission Forum
Thursday, August 06, 2009 11:46 PM
i was just wondering what is the major differences between a short shifter and stock? just a curious question because i just cut like an inch and a half off of my shaft so i was wondering if that is the same or is it what you cant see that is different?
Re: Short shifter explain....
Friday, August 07, 2009 1:10 AM
The difference is in what you can't see...short shift refers to it being a 'short throw shifter'...the pivot ball that is connected to your shift linkage cables is shorter and angled differently than stock. This results in the "throw" of the of the shift, or how far you moe the shifter, making shifts quicker and smoother.
Friday, August 07, 2009 1:40 AM
haha
wow...
i didnt know anyone still thought cutting it was the same. same distance of a throw x2 for Evilution up there.
Friday, August 07, 2009 1:54 AM
Levi Weuve wrote:i just cut like an inch and a half off of my shaft
OUCH!!!
that HAD to hurt!!!!
LoL
Friday, August 07, 2009 10:23 AM
OUCH!!!
LoL
HAHAH!!! still pushin about 14 tho lol.....
AND I didnt think that they were the same....thats why i asked. Im just learning is all lol
Sunday, August 09, 2009 6:23 PM
A short shifter will be longer below the ball so it requires less travel above the ball to equal the same amount of throw or cable travel below the ball.
Tuesday, August 11, 2009 12:29 PM
so you if you really wanted to you could probably make one......not that it would be identical but you could cut it below the ball and weld a socket or somethin in to make it a bit longer? cause ive read on some other forums about people doin this buy it wasn't the same kind of shaft set up
Tuesday, August 11, 2009 9:32 PM
^ ^ ^ Yes, I extended mine an inch with 1/2" diameter rod.
