I need the part # for the interior wiring harness that runs from the BCM to the gauge cluster, steering column, stoplight switch,
Clutch saftey switch, . Its just a matter of looking under there and getting the part #'s off the wiring harness. I am pretty desperate here as i was this swap pretty much plug and play as possible.
Or w/e harness the clutch safety switch is on because the one i have now, well apparently just doesn't cut it because its for an automatic. GMpartsdirect's catalog won't list anything.
Edited 1 time(s). Last edited Sunday, January 20, 2008 3:52 PM
do you still need this # or did u get it
nope, i've got 3 of em right now. Probably working on a 4th.
I know where there is a 5th for ya. 04' 4-door, 5-speed w/ABS
Tinkles wrote:I know where there is a 5th for ya. 04' 4-door, 5-speed w/ABS
I need it w/o ABS..... ABS is the devil.
pull the abs relay
(if its that simple
12.33 @ 111.67 mph [Oct 2009]
327.6 WHP 333.6 WTQ [10.1 AFR]
Actually im not sure if that harness i mentioned has ABS. At the junkyard i noticed a block with brake lines running in and out of it and was located next to the brake reseivior. I assumed it was the ABS controller. But with looking at my 03', im not too sure. My 03' has the same block, but doesnt have ABS.
