5th Gear??? - Transmission Forum
5th Gear???
Sunday, October 01, 2006 8:50 AM
Hi everybody.
When I drive my car during a cold morning, my 5TH gear give resistance and don't want to go in. If I double clutch it, it's OK, no problem. 15 minutes after I start, it give only little resistance and go in... I don't know much about transmission, but it seems that the temperature of the tranny has an influence on this... What's the problem?
And it's a 5speed 99 cavalier Z24
Re: 5th Gear???
Sunday, October 01, 2006 4:58 PM
anyone?
Re: 5th Gear???
Sunday, October 01, 2006 5:54 PM
When was the last time the tranny oil was changed? Sounds like it could be overly thick fluid.
Re: 5th Gear???
Monday, October 02, 2006 4:44 AM
It was changed last year, I drove all winter wtih this oil and no problem...
Re: 5th Gear???
Monday, October 02, 2006 4:45 AM
and it's only in 5th gear, all other gears are fine
Re: 5th Gear???
Monday, October 02, 2006 4:48 AM
It still may be possible since technically 5th gear is "outside" the case with relatively small holes to get oil to it.
Re: 5th Gear???
Monday, October 02, 2006 4:57 AM
I don't remember very well, but I think my mechanic put motor oil in it to be easier to shift in winter
Re: 5th Gear???
Monday, October 02, 2006 7:19 AM
motor oil thats not what you use. ive always used GM synchromesh.
Re: 5th Gear???
Monday, October 02, 2006 6:42 PM
other suggestions?
Re: 5th Gear???
Tuesday, October 03, 2006 12:28 PM
Does an oil change will fix this?
any input is welcome
Re: 5th Gear???
Tuesday, October 31, 2006 6:51 PM
since i switched to synthetic 5w30 back in 2000, i have had no problems.
yes, 5w30 in the transmission.
Re: 5th Gear???
Wednesday, November 01, 2006 3:16 PM
never put @!#$ motor oil in a transmission thats what the mechanic wants somthing to break so they get the money to fix the prblem go to a chevy dealer and get it done RIGHT!!!!!
Built&Boosted moar
Re: 5th Gear???
Friday, November 03, 2006 10:22 AM
I don't know. Motor oil probably isn't all that bad. Manual trannies use various oils. Hell, the Getrag uses ATF....
And i do know some take 5w30. Although, I would always use what was recommended by the manufacturer.
"The Blue Bullet"
Re: 5th Gear???
Saturday, November 04, 2006 4:45 AM
i work for GM and we never use motor oil in any trans
Built&Boosted moar
