i need a part number - Transmission Forum
Saturday, September 09, 2006 8:31 PM
i did a search on here and on the net using google and i didn't quite get the info i was looking for.
i would like to know the part number for the flywheel to crankshaft bolt for th 2.2L ecotec engine and the pressure plate to flywheel bolt (i have a manual trans.).
i'm doing an ecotec swap in an '01 cavalier that has a 2200. are the bolts (flywheel and pressure plate) the same for both engines?
any help is appreciated, flame if you must, i'm just trying to save myself an hour drive to the nearest dealership.
Ahhhh.... I see the screwup fairy has visited us again...
Re: i need a part number
Saturday, September 09, 2006 9:43 PM
If the bolt looks like any normal bolt (I.E. Standard fully threaded bolt, or smooth shank). Then you could most likely get a new one at Home Depot or a hardware store. Make sure you get high grade though, grade 5 would be the minimum i use on a car. I'm in the process of replacing my control arm bushings and kinda FUBARed one of the bolts, so i went to home depot, matched up the threads, and got a grade 8 steel bolt. Tell ya what, that sucker aint breakin on me now.
But yeah, if it looks like a normal bolt, you can easily replace it from Home Depot or Lowes, just make sure you get grade 5 or higher, they're more resiliant forms of steel.
Freakin morons.... When will they learn. Hold On Not Done Accelerating
